They found it today everyone! out in West Croyden with a bunch on clothing, cigarettes,USB, Holden jacket (typical) and sunglasses in it. With apparently no cosmetic damage apart from broken window and ruined ignition barrel. But I will get to see it tomorrow after TAFE,
Thank you everyone for your help! and would be keen on one of those GPS trackers! :)
It apparently was used in multiple high speed pursuits over the weekend, so I am mechanically worried and about possible damage. Is there anything I should specifically look for when i go examine it for any damage?
Great news man!
I'd probably do a service and take it for a long drive, you should be able to notice anything sinister through that, might pay to plug her in to a computer and just check the error log.
Good to see you got it back dude!
First things first. Check all suspension arms en a wheel alignment. If they were driving it like its stolen they wouldn't care about gutters and they probs got some air on it lol
Oil change for sure just to be safe :)
Glad to hear Josh. The little so & so's need their hands broken with a 4lb copper hammer! As everyone else said about checkin it out. Get it up on a hoist, full service, wheel alignment (It sucks that insurers won't cover tyres!), if there is gutter rash as Hugh stated, make sure every rim spins true! Definately up for the trackers. PM sent.
Currently at Jaustech being completely Sussed out. Went and had a look last week, was pretty pissed off after looking at it.
Drivers door needs replacing, clutch is gone, some scratches, plastic dash fascia missing in most places. Inside mirrors ripped off, center console snapped, head unit fascia cracked, ash tray broken, glove box broken, cigarette burns. Extremely filthy....
Will be at least a couple weeks until I get her back.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
