Hi Guys
Got these done as part of my current build but have decided to go a different direction with the engine bay look/colour scheme so they are up for sale...
As part of the sale I will require your the same stock parts/covers in exchange, I do already have a spare spark plug cover so if you don't have this item we can work something out
The set comes with a brand new R34 GTR engine plate (as pictured). This item is brand new in the box and was only sat on the spark plug cover for the photos. It will also come with a brand new TWIN TURBO badge (not pictured).
Details are:
Condition - professionally polished and have not been fitted/used since
Location - Brisbane north side
Shipping - Will ship Aus wide, cost depends on your location
Price - $700 + your stock parts/covers in exchange
Photos - see below
Contact details - PM or call/txt me on 0407 175 417
  • 4 weeks later...
Sale fell through and I do not need covers in exchange now...
Updated details below:
Price - $850
Shipping - pick up is fine or delivery Aus wide should be around $50
how much for just the twin turbo pipe??
PM sent
A good buy folks - get on to this
Cheers mate
How much for twin turbo pipe and rear turbo pipe exchange ?
PM sent
  • 1 month later...
  • 3 weeks later...
Price update:
Twin turbo pipe + elbow - $150 + delivery
Engine covers - $650 + delivery (will also come with brand new genuine Nissan CAS seal)
OR
The whole lot for - $770 + delivery
  • 1 month later...
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
