Fully Sick Sporty KIA Rio with bonnet scoop!
Guest Munky
Hey,
Just thought I'd post some pics of a 'sporty' looking car I saw at uni this week. From a far I saw the bonnet scoop and thought it may have been a civic sedan (which would be funny anyway), however as I approached it I saw the well respected KIA badge on the front. Sarcasm aside, this would have to be one of the more pointless mods I've ever seen on a car (my mate has a KIA and we always make jokes about how he should invest in a kit - little did I know KIA kits even existed!!).
Has anyone else seen any outrageously bad/unnecessary mods to similar cars? I remember seeing another person driving around uni with a civic where the only mods were fluro mud flaps.
Anyway, hope you find some humour in the attached pics and apologies for the bad quality - they were taken on my phone camera.
Cheers
EDIT: Removed plates!
Hey,
Cheers
I saw a car today that made me physically sick...
It was a lime green metallic VN Commodore, some kind of lower bodykit and a GT wing on the boot
The GT wing and portions of the bodykit were painted bright purple as well as the window surrounds.
It had a stock ride height and 15 inch mags
What an atrophy...
I remember sometime ago they did release a limited run of this blue wrx lookalike model. So I believe the way that KIA looks is how it came from the factory, correct me if I'm wrong.
Unfortunate for the owner, he/she not only paid to get a lookalike WRX but also the attention of being laughed at.
Yeah, used to be one parker in the shopping centre at my local shops (yes, IN they have some shop set up with a few cars there, pretty dumb idea. CAN I TAKE IT FOR A TEST DRIVE MATE?) anyways, a crummy blue one like that featured there for a while... my mates and i always had a good laugh at it on the way to Coles. :P
Seen 2 "fooley seeck" holden astras.
A dark red one with a weird bodykit, mesh grille, fartcan exhaust and chrome wheels.
Another blue one which had a fartcan, chrome wheels and 2 (yes 2!) spoilers. One on top of the other.
Both drived by people on p plates with cappa jackets and fubu caps
Saw an old late 80s or possibly early 90s Falcon GLi (square-ish shape) with a tail light black plastic insert to create an illusion of Skyline's 4 round tail lights.... LOL hahaha.
Last seen @ McDonalds Clifton Hill, seen it around there 2nd time already, so could be someone who lives/works in the area.
Untill you've seen an excel that has pink interior, body kit with some sort of spaztic plane wing that moulds into the back of the car, fully sick sports zorst that sounds like one of those wet farts that dribble and the portions of the body kit that are not stardard are painted in blue, you have seen nothing!!! :bonk:
i saw something in a car mag here that beats the daewoo :)
a peugot 106 with bodykit, mags, paint, wing, etc.........NO speed enhancing mods, but they still put a racing harness in it ;) infact with all the extra weight. a stock model would run faster........remember this is a 1.6L engine so they didnt really need a racing harness :headbang:
oh and this was the feature car for this mag, not a piss take..............
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
