hi guys,
i just noticed the other day whilst filling up my 04 v35 coupe, that the metal flap where you put the nose of the petrol gun in is missing!
just wanted to know if this is standard? im pretty sure all cars come with that metal flap, just wanted to know whether mine has broken or something?
Please advise so i know whether its broken or its like that.
thanks!
https://www.sau.com.au/forums/topic/410752-fuel-metal-flap-v35-coupe/
I'm no too sure if its stuck inside ill try again when I take it out but last time I checked I couldn't feel anything...and Greg are u sure I've checked a few other cars at home and they all have it? Jut need a few more people to definately clarify this
My V35 doesn't have it.. and I just double checked the J31, it doesn't have it.
I don't think my old 1993 J30 Maxima had it either.. the R31 skyline I had before that did though..
It doesn't really serve much of a purpose.. other than to prevent you accidently dropping something down there.. but really, how long do you have the fuel cap off without a filler nozzle blocking the hole?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
