As title says i'm selling up my project.. Few life changing things popped up an now havent got time or money to continue..
I was working FIFO, so i've spent a shitload on this motor+setup..
Alot has been done to the motor including alot of secret mods by the builders..
The long motor will be for sale on its own with no hot side... Motor is brand new, hasnt been started.
Block:
-Full nitto engine gasket kit+metal intake/exhaust gaskets
-Machined
-micro polished and grub screwed crank
-block dipped, crack tested, chemically cleaned, deburred
-New timing belt tensioners
-Nitto crank collar
-New welsh plugs
-ARP main studs
-ARP rod bolts
-Eagle forged rods
-Cp pistons with custom gudgeon pins
-1.3mm block restrictor
-Rear head drain
-Fully Balanced crank, pistons and rods
-Ati super damper balancer+water pump pulley (1000hp model)
-ACL race bearings
-Greddy pulleys+ HKS belts
-N1 new water pump
-Custom sump
Head: (Jun style port an polish+mods on the heads)
-Machined
-Full port and polish
-cc chanbers
-chambers polished
-arp head studs
-deburred
-Oil returns champhered
-1.3mm commetic metal headgasket
-Supertech oversized valve
-Custom bronze valve guides (strongest you can get)
-hks 272 10.2mm lift camshafts
-Head machined+shimmed to fit cams
-hks step 2 valve springs
-jun titanium retainers
-HKS adjustable cam gears
-HKS timing belt
-Trust clear timing belt cover
- -12 fittings on cover
The motor also comes with:
-r33gtr powersteering pump modified to work with ati balancer. (very rare to find 33gtr pump)
-Alternator + Bracket
-Inlet plenum.(underneath plenum all wiring and parts have been simplified so you dont have a whole heap of junk)
-Freshened up starter motor
I'm asking $13 500ono for the long motor.
The dry sump setup has everything you need to plug and play.
Comes with:
-Dailey engineering 5 stage external pump+pulley+pump mount
-Motor pulley+ mount+ belt
-Braided lines(Metal+race lines) and fittings in -8,-10,-12,-16 (All Aeroquip)
-20l oil tank+mounts
-Oil catch can+filter
-Custom dry sump, sump
-Pressure regulator
All of these parts are brand new, asking $8000.
High octane sell theyre dry sump kit for $9000+ an that doesnt include $2500+ for lines an fittings and a 5 stage pump.
-Also have a Rb25 gearbox in perfect condition. Not even a scratch on the teeth $1450ono
On the turbo side i spent over $5000+.
It comes with:
-Polished+ceramic coated Precision 6262 twin scroll,.84 ex housing(dual bearing model)
-Ceramic coated manifold
-Twin Tial MVS external gates
-Braided lines
-Clamps+Gaskets
-Quickspool Valve
Asking $4000 ono
I'm not sure if you's know what a quickspool valve is but what i was trying to achieve from this motor was a extremely responsive motor which could still rev out unlike an rb30 and still make big power.. Thats why i didnt go down the stroker route..
Any questions pm me.
Cheers
Ibz
Edited by ibz
If theres someone whos after the bottom end i'd be willing to seperate..
I'll be selling everything in this thread (http://www.nissansilvia.com/forums/index.php?showtopic=388331&st=210) once motor,turbo and dry sump setup are sold...
  • 1 month later...
  • 11 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
