I just recently had a service and a week or so later noticed my back brakes sqeaking.
Pulled my wheels off just now and both back brakes appear to be slightly on. I can turn the wheels when the car is jacked up but when they are off i don't have the strength to turn the hubs.
Could my handbrake be adjusted too tight and be slightly dragging or is there another possibility here?
Thanks.
https://www.sau.com.au/forums/topic/41091-hand-brake-adjusted-too-tight/
not sure sarpi :P as per above there are small drums behind the discs on the rear hubs for handbrake only.
As for brake pads, they always touch the disc lightly...so thats not necessarily a sign of a problem.
When the car was serviced were the rear brakes touched? maybe the anti squeal shims were not put back?
Good call on the shims - if you dont put them in the brakes make alot of noise.
When you jack the car up to turn the wheel, are you doing one side at a time or both sides?
If you are concerned that the handbrake is over adjusted, jack up both rear wheels, and have a look on the inside of the disk/drum (diff side) there is a wheel inside that can be rotated with a screw driver to adjust the tension on the brakes. Back it off until the wheel turns.
Better still, take the car back to the original place and get them to do the job properly:)
Adam, if the pads are new you may not be able to rotate the hub by hand. Try spinning it with a wheel attached. You should get 1 or 2 rotations with moderate effort.
Still doesn't explain the squealing, as was mentioned maybe check the shims.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
