Hey guys,
I have a 1998 Honda EJ8 Civic Coupe (manual) up for swap for any manual turbo sil or skyline. Car is currently on around 260k all highway k only from the previous owner (female), bought it around 250k. The engine is very healthy and strong, run smooth. The car have logbook, all the receipts and paper work. Car color is silver, 16" alloy wheel with 90% tread. The interior is immaculate!, exterior the paint is excellent! All electronic is working, a/c and heater all work perfectly. Timming belt had been replaced at around 215k. Car have been serviced regularly by previous owner and now me, I just serviced it at around 500km ago with Castrol Edge 5w-30. Car have 11 months of rego. Very well looked after, never been in any accident. Always use BP Ultimate. The only reason I let this baby go is I want a turbo car.
Good:
Ported & Polished head for more little bit more power and torgue, good for daily (good P&P job).
Injen CAI
Megan Racing header 4-2-1 (few week old) for low and mid range torgue, again good for daily driven.
Bad:
Sump gasket started to leak due to aged, just minor leak, nothing major (easy fix). Planned to fix it myself, but have no time.
Few small dents and 2 minor scratches from stupid people at the car park :( very hard to notice.
Anyone want a good looking daily driven car, this is the car for you, you will not be disappointed. If you are interested, please let me know via pm or text 0403201566.
Here is a few pics:
Edited by samyip
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
