I got the TDX2 exhaust system from Motordyne about 2-3 weeks ago and it has been on the car for about 2 weeks now.
First off installation didn't take that long (I didn't do it myself got an exhaust place to do it for me), it was apparently quite tight in some places but I expected that from what I have read off the interwebs.
When I drove the car for the first time, my initial reaction was 'this is LOUD!'. There is a kind of drone whilst in the lower rev range but when you open the throttle, it sounds amazing! The best bit about it is if your driving along the highway or at a set speed its as quiet as stock.
I got some pics and a video (although with some rather tame revving of the engine):
Box:
The whole system laid out:
Video:
If anyone is interested I can post how much it ended up costing all up, for anybody thinking of getting it.
Edited by xj265
https://www.sau.com.au/forums/topic/410998-tdx2-installed/
Awesome! So you just got the MD TDX V2 without the ART pipes? I am yet to hear how it sounds without the test pipes, meant to be insane with them!
Please do, post how much it cost you delivered i'm in QLD too so it should be similar
https://www.sau.com.au/forums/topic/410998-tdx2-installed/#findComment-6568751
Yeah I only got the TDX2 no ART pipes, I wanted to keep it legal however I'm sure its already illegal due to its loudness haha
So all up it was:
1635 (TDX2)+
547.57 (delivery to my door)+
348.52(Custom and GST charges)
$2531.09
Please keep your opinions to yourself on whether you would spend this much or not
Even with stock cats, there is still a fair bit of 'gargle' from the exhaust. With HFC and espically ART pipes I should imagine there would be a lot more 'gargle'. I might look into getting some HFC but I don't want ART pipes.
https://www.sau.com.au/forums/topic/410998-tdx2-installed/#findComment-6568853
I'll get some audio of my setup for you Sean.
Please do
So all up it was:
1635 (TDX2)+
$2531.09
I kind of like the gargle, the system is definitely one of the best for the VQ IMO. That price is expected, shipping absolutely kills us!
https://www.sau.com.au/forums/topic/410998-tdx2-installed/#findComment-6568956
Yeah I get in cabin drone from 1.5k rpm to 2.5k rpm, it worse going uphill. I think auto box has got a lot too do with it, I don't get it using tiptronic mode.
Been thinking a MD ART -> MD XYZ with HFC -> Exotic Speed R1-T setup lately, Shiva maybe you can try out that setup since you got the Exotic Speed R1-T?
As I'll most likely be installing my Berk HFC on, instead of that setup.
(null)
https://www.sau.com.au/forums/topic/410998-tdx2-installed/#findComment-6573422
Hey all, since there's been a lot talk and interested in Motordyne products, particularly the Shockwave TDX2 Cat-Back Exhaust System. I've seeked a quote for the Shockwave TDX2 Cat-Back Exhaust System including shipping and so on, based on a 10 unit purchase.
Also there are a number of other Motordyne products that you may be interested in, such as ART Pipes, XYZ Pipe and Sway Bars. So express your interest via private message in which product you want by next Thursday (18th October 2012), so I'm able to provide the group buy facilitator the exact numbers to get a quote for.
Now the way the shipping will probably happen is that each buyer will provide the shipping address and the shipping quote will be individual to each buyer and the items will be shipped directly to the buyer (unless you can team up with someone in your own city), this will save cost on double handling. Note, that most of the savings will be on the units itself and there may be savings on the shipping too.
As always with group buys, the more buyers there is, the lesser the cost will be to each person on the units. So if you are intending to get these down the track, I suggest you get onboard and if you don't have the funds then borrow some money, as this will probably save you a fair bit down the track.
Looking to close the group buy and make payements by Thursday on the 1st November 2012, as there will be lead time on some of the products and shipping time. Also, we would want to get in before December comes, as they will be delays with holidays and the amount of shipping that occurs with the Christmas period.
https://www.sau.com.au/forums/topic/410998-tdx2-installed/#findComment-6575677
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
