First owner in Australia since mid 2010 still got papers of purchase from the car yard (SSV) in oakleigh.
*Rare* 2000 R34 Skyline Series 2 in factory Bayside blue.
Much nicer interior than Series 1,
two tone interior black / silver and Suede seat, Clear indicators, Nismo front n side skirts
Car is making 271.5 rwkw @18 psi on V-power
can make more with few more add-ons
turbo is capable of 450HP
GOODIES:
PU High flowed turbo done by *Hyper gear*
Nistune ECU
Sard fuel system:
Fuel regulator
Sard twin entry rail
650cc injectors
Koyorad radiator
WALBRO fuel pump
Z32 air flow meter
K&N pod filter plus silicon pipe (in after market air box)
HKS return flow FMIC, No holes cut
HKS actuator
HKS exhaust
Heavy Duty Extreme clutch plus light weight Fly
R34 GT-R Brembo Brakes
GT-R master brake cylinder
18” Wolf S36 with toyo tyres front tyres and Achillies Rear
wheel
HSD Coilovers
Camber and rods parts *unknown brand*
Swaybars front.rear also Unknown brand, they are blue so assuming cusco?
Strut braces front/back *unknown brand*
L.E.D backlights
Factory xenons headlights
Nismo triple gauges
Viper alarm and kill switch ;)
All mechanical work and tuning was done By Dr. Drift *Sam*
Recently tuning done by Trent * Chequered Tuning*
Recommend him top job, start going there people
All suspension work done at Centreline suspension
Just recently had a full front re-spray done.
Recently put in a new battery and all 3 belts, also replaced alternator.
Car always serviced with the best of oils, Motul 300V and drift filter each service.
Serviced every 5k’s
Washed at least once a week
Always filled up with shell V-power.
The car is one of the cleanest going around and won’t disappoint.
car comes with NO RWC, but i can assist with it,
mechanics tend to be harsh for sellers and easy for Buyers.
Asking Price $22,500
No Test drives allowed *insurance issues* until a deposit is put down. A refund of the deposit will be returned only for genuine reasons
Please feel free to call or SMS me on 0413 658 358
Edited by YF34R
i may be wrong do you mind clarifying, i was told that bayside blue only comes on GTRs, so did you mean that it's been resprayed in the factory BB? sorry if that's obvious to everyone but me.
I can verify this the code is tv2 it's factory option I have it too mint car and good luck ^__^
Hi guys,
thanks for visiting :)
yea its from factory code on plate TV2
i heard that they sprayed 2000 cars by mistake in one day in GT-R bayside blue.
but tom says that they came as in option for Series 2 so i might be wrong lol
just curious: if i wanted you to reduce the price, what mods would you remove and how much would the price go down?
feel free to PM me the answer, i think that's better
Edited by darksky34
I want this so bad! Too bad I don't have the money and still restricted by P plates :(
If this doesn't sell soon, I will be very surprised
ye its pretty much sold lol,
some guy already left a deposit just waiting on mechanical check with it will pass with flying colours.
just bumping it so if it falls thro and he cant provide the funds, others can have a chance to buy it :D
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
