  • Replies 43
Youtube Links.
Dropbox sucks for streaming.
I'm lost for idea's. Figured if it was a head gasket it would be constant smoke? Get worse with rpm's as pressure builds up? PCV valve cleaned, made 0 difference. Although it was gunked up and rattled when i shook it (think thats normal)
http://www.youtube.com/watch?v=UVU3XbimIsc
http://www.youtube.com/watch?v=G3aQ_biZaf0
Edited by Booki
Going to start taking it all apart tonight...just after i had put my sweet new -7's in :(
Anything else I should be changing while the head gasket is out?
Recommendation's on head gasket? (genuine, after market? Nismo? cometic?)
Edited by Booki
Just replace i with a standard gasket from Nissan. They aren't that expensive and are very good quality.
Get the cylinder head fully recoed while it's out. Valve regrind, stem seals, deck ect.
Get your injectors cleaned right before the head goes back on
Replace all the heater hoses
Still running stock injectors, worth spending the cash to get them cleaned?
Are there better options out their then the standard nissan gasket? While i would imagine they are good quality, I am planning on running 17-18psi boost on the -7's, would the standard gasket hold up? Or should i look at something after market?
Know any places that are reputable to get the head done? And rough costs involved?
Edited by Booki
We use stock gaskets in applications over 600hp and 30psi boost without issues.
If you do the job correctly, it will be fine
Anybody got any tips for taking the head off?
Both turbos are back out.
Cam gears and belt still on, looks like my cam timing is one or two notches out on the exhaust side...
Do people remove the head with the plenum attached? It looks like a bitch to remove the brackets hiding underneath the plenum.
Honestly surprised myself in how quick I was able to remove the turbos
Edited by Booki
Well for all those following, Heads off.
Now with the head out, I will send it off for a reco, though in the process their were some casualities. I ended up cracking it and just cutting a heater hose, and a two electrical connectors were damaged. Anybody know where to get a replacement heater hose and this particular electrical connector?
The other I am hoping to just open the connector, and solder/crimp it back down.
In the mean time I am hoping to get a neater engine bay setup, wanting to eliminate some hoses that are not required. Mostly the ones under the Plenum as they were a BITCH to get out!
Also, This wiring looks real dodgy and pox as, I don't think its standard/original wiring. Can anybody confirm? Then i will start following it up and eliminating it. Or at least making it neater.
Edited by Booki
Top hose in the pic that is broken - get it from Nissan (Usually the first place you should try)
The plug should be the same as Bosch 2 pin standard so I would try Repco etc for those. Pretty common plug. It won;t look the same but should still fit the Bosch 2 pin knock sensor.
The other wiring is anyone's guess
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
