Hello SAUACT,
Me and my two imports will be moving to Canberra early next year and I’m trying to work out what to do about rego/licence.
Am I better off keeping my NSW rego and Licence (I will still have a valid NSW residence) or should I transfer everything to ACT? I've already looked and it seems like rego costs will be about the same either way and insurance won’t change too much.
My main concerns are how strict are ACT police/laws for mods/defects vs NSW and how much trouble will it be to change everything over? And If I do change to ACT rego and I get pulled into a defect station in NSW what’s the go?
I've got an 180SX daily and a 300+kW Autech 260RS, I haven't had any trouble in NSW yet but I don't drive like a jerk.
Any help/advice would be greatly appreciated and maybe I'll see some of you at a meet some time.
ACT is generally more mod friendly. You just need to pass that first inspection coming into the ACT.
Never had an issue with either ACT or NSW, but I've also never seen an EPA stop either. Should not have many issues with a volvo wagon :)
Yeah I did get the impression that the ACT was a bit more mod friendly. General i've found ACT police to be much nicer than their NSW colleagues.
The Volvo wagon disguise i probably wearing a little thin in the cars current shape- Low, GTR rims, Loud exhaust + the Autech bits, body kit, brembos, FMIC etc.
The engine bay if full of pollished piping but the pods are enclosed.
Hmm... How tight is the inital inspection? Mods list below includes a lot of things an inspection shouldn't uncover but also a lot of things that "should" fail in NSW
Autech S15 seats
R34 GTR wheel
Lowered springs on standard struts
M35 steering wheel
Freeway dolphin gauge pod on dash
R34 GTR turbos
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR mounted on steering column
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
"High flow" cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
It all depends where you take it... If you have to take it to the pits they might be a pain they might not. If you only have to take it to an ACT approved inspector i highly doubt you will fail. I had my GTR pass easy. If you can take it to an ACT approved place try to find somewhere that doesn't deal with modified cars much. I have found that they just make sure its high enough, check the lights and make sure no leaks. Then you are good to go.
But like i said i can't remember if you will have to take it over the pits... ask verms he did just move is Autech stagea across. I know he gets his done at Ultimate tunes and they where pretty good. I used to take the GTR to capital automotive in fyshwick as the guy that runs the place is pretty good.
p.s that does sound like a nice stagea.
Autech S15 seats
R34 GTR wheel
M35 steering wheel
R34 GTR turbos
Walbro fuel pump
Power FC
Z32s
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Fujitsubo Cat back
"High flow" cat
Turbosmart BOVs
Most likely get picked for the stuff I marked in red.
Try hide it and get your ride at the legal ride height.
Mainly too low, too loud stuff.
So unplug the AVC-R, the P-FC is behind the kick pannel so that should be fine and the BOVs are actually plumb back mounted in stock location.
I've got plans to get some coilovers as i'm not happy with the ride on the stock struts so i'll just set them above 100mm when that happens.
I'll try to borrow a dB meter so i can work out if i need to do anything with the exhaust.
Sweet!
Thanks everyone for the help with this
The power fc shouldnt be an issue and let me know if i can assist in anything as my car is nearly stock with a few modifications.
I still have the standard ecu if thats an issue! let me know when your in the state and well meet up!
Thanks everyone for the offers of stock parts. I move down in January but the cars are registered in NSW till the middle of the year. So i think i'll tidy the cars up and take them for inspections asap and then i have plenty of time to sort the cars out if the fail.
We've got a dB meter and emissions tester at work so i'll try to borrow the dB for a weekend.
Yes M35 steering wheel, heaps cheaper than a replacement stock one/GTR wheels and much nicer/legal than the Personal deap dish wheel that was on the car, it pretty much goes straight on. The clock spring just needs a little foreplay/dirty talk to make it fit.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
