Location?
Central Coast NSW
Would u b interested in swaps for a set of recaro sr3 with recaro rails? Im in newcastle. Send me a message on 0401631925 if your interested?
nah im already running a pair of Bride Gias II
No Japanese bolt in cages are cams approved due to the thickness of the main hoop.
Must be 44.45mm thick (if I remember correctly)
Can easily be changed.
That's the only thing for a cage you need basically
cheers slide, looking to do wakefield track days in my track 32 just dont have the 3000 i need for a decent weld in job yet. So this was my next alternative. Good to see its a sun roof model so will fit mine :)
i can certainly take measurments incase it has been changed. It was in my car when i bought it. Havent been into the whole track thing for some time so unsure of the measurements/specs any more
cal the car is an ex drift car so should be no issues on the track :)
  • 1 month later...
Yeah calaonic
The rules here in Victoria recently changed due to an accident resulting in injury on the track so the jap cages are worth nothing here anymore and everybody has gone custom weld on cage jobs.
VICdrift has changed the regulations according to cams spec which is the thicker diameter main hoop.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
