Psychopharmacology, Nuttitional Psych, Hypnotherapy, Counselling
I sort of love the detective work of tracking genetics, ancestry, biochemistry and microbiology most of all.
For instance us Asians tend to lack Lactase (thus lactose intolerant), Aldehyde Dehydrogenase (we get drunk quicker), don't process Vit A as well as Caucasians and we're often born with big teeth on small mandibles (common to have wisdom teeth extractions)...
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901222
So you carry your bottle of Lacteze to dinner?
Funny how I sometimes recommend it but I don't have any myself.
Birds I don't have dairy very often away from home, and I'm usually too full to order a cheese platter.
Yoghurts can get me going sometimes.
I think Lactaze or Tilactase has short dating for those considering it.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901254
interesting
I'd love to find something to help me with my sleeping issues, but I don't want to take any medication so I probably can't
I don't like taking prescribed drugs myself unless absolutely necessary - but supplements are a different matter (when justified).
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901257
I may have mentioned before - maybe not - that different supplements may be more useful than others depending on the type...
Insomnia Type I - where one can't get off to sleep...
Insomnia Type II - where one wakes up intermittently
Insomnia Type III - where one wakes up too early and can't go off again
Rider:- Rotating shift work, pregnancy, cardiac issues (like fibrillations and mitral valve weakness) can upset all of the above
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901529
I have insomnia type 2 most nights and type 1 about once or twice a week, when something upsetting has happened during the day or I'm anxious. I usually get between 3-5 hours a sleep per night for about the past 7 years. I'm pretty used to working full time, studying part time and going to the gym 6 days a week on little sleep now; however I think lack of sleep affects me emotionally.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901728
A long time ago, I had insomnia of a similar kind for over 5 yrs Leesh. I used medication to 'reset' the sleep pattern so to speak over a few months. I went days without sleep sometimes. Eventually it caused me some physical health issues.
Also, you fall into a pattern and the 'lack of sleep' thoughts further add to your stress ,causing more lack of sleep.
The medication I used basically 'puched my lights out' at a time when I wanted to go to sleep. It had some side effects that I would say are nothing compared to long term lack of sleep and go away the moment you stop taking them.
Go ask your doctor to help you out there it's worth it.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901886
If you want a otc supplement try Dorian Yates GH Blast. It has GABA, ZMA, arginine glutamine and macuna purians in it very good testosterone and GH support and assists sleep
I have a hormone imbalance and my body produces excess testosterone, so is this supplement appropriate for me?
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6902435
From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
Edited by XGTRX
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6902460
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
