hey all. just wanted to pick peoples brains. I'm just trying to figure out if the car mounted speed 'safety' cameras that hide in the trees and other area's you cant see them have the same flash set up that fixed camera's have?
Ive just never seen any operate late and night and was curious.
I think i got done near the ingle farm shops on Montague road at 1am this morning. Car was hiding in the trees, the flashes were about 3 seconds apart which i think was too long (compared to the fixed ones)
im sure i was really endangering life doing 67 in a 60 zone at 1am on a cold drizzly night. maybe the rain will give a false reading:)
im guessing i def have been done but never noticed the car ones operating late at night (i bet the driver wasnt even in the car, it was probably parked out the front of his house and he wasn't in the car)
https://www.sau.com.au/forums/topic/412800-car-mounted-speed-cameras/
Nothing worse than thinking you got done, i reckon i went through a mobile one the other day on churchill rd, not to mention in the work van to make it worse. So im anxiously checking the mail box each day.
Anyone know how long they roughly take to send out the fine?
Rather take the points than the fine to be honest, but be interesting to see if i did get done, even now im still doubting whether i was over or not.
On second thought they have changed it now haven't they, you get more points and less of a fine? Still thinking it was 1 point and 200plus fine for about 5-10kmh, its 2 points now and 150 or so?
Edited by Grimesy
hang your front number plates on loose cable ties. as you drive faster, the wind pushes them up under the bumper and out of sight. im sure theres a way to rig the rear one to do something similar...
or drive slower
easy fixed
or drive slower
easy fixed
seems fair, but being done for 65 in a 60 zone seems a bit harsh. i know ive been done so have to cop it on the chin. im sure maybe light weight hindges on numberplates might work too
btw i've been flashed twice on the kwaka really late at night, and i'm 100% i was on or below the posted limit. Maybe they flash every now and then to ensure they are still working, or to just throw fear into people.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
