hey guys
Shell is now for sale... It wont be available for the next two weeks as im still in Brisbane and the shell is in mackay
please note - a little bit of fabrication skills would be necessary to finish a few things off on the car
Info:
Front windscreen cracked
Steering coloum shaft will need to be replaced
Stripped interior, not one bit of wiring harness front to rear
Front guards modified as per picture
Custom dash reo bar made
Custom alloy dash made
Sound deadening partially removed - just the stuff i could get with dry ice.. Some still baked on like around the gbox tunnel
Front radiator support cut out - was planning on welding a couple tabs to it then bolting it back on via the tabs
Lower front chassis brace cut out and replaced with a piece of tube to give the radiator more room and be able to have the intercoler sit upside down and have its inlet and outlet very close to the intake mani and turbo for short piping.
all fuel and brake lines have been removed
aerocatch bonnet pins
led taillights
will throw in the whole car loom and all ecus that i have.. loom is cut in a few spots and one ecu is damaged.
Thats about all i can think of at this stage
It is a registerable car
The price will vary depending what you would want to come with it, in its base form:
No driveline just suspension arms minus the cusco hicas arms and swaybars
No wheels
No suspension
No frontbar
No lip
No wing
No brakes
No 4wd Pump
$1500
If you want it to come with other parts let me know via pm or phone call and we will sort out a price
I dont really know how to send a shell interstate so im going to go ahead and say qld buyers only and i dont really have the time to transport it for you.. you will need to arrange all that yourself.. i will however help you get it on a trailer but bring your own wheels unless you are buying mine.
other parts for the car which can be added into the sale with some discounts here and there;
r33 gtr gearbox, recently rebuilt with new bearings.. has not been run since - $850
r33 gtr/gtst fuel tank, no pump - $100
r33 gtr nismo in-tank pump - $250
r33 gtr BC External Reservior coils, as new only fitted and moved 50metres - $1350
r33 gtr black oem front bar, good condition paint is scratched a bit - $500
r33 gtr/gtst greddy front strut brace - $125
r33 gtr/gtst oem rear brace, have two of these for sale - $100ea
r33 gtr carbon fibre grill with no symbol just mesh - $100
r33 gtr rear wing, carbon end caps - $350
r33 gtr front lights very good condition - $350
r33 gtr/gtst cusco hicas lockout bars very good condition - $250
r33 gtr cusco front swaybar - $250
r33 gtr moonface racing castor arms - $200
r33 gtr passenger seat, good condition - $150
r33 gtr/gtst fuel tank - no pump - 100
r33 gtr diff - $400
r33 gtr genuine autoselect front lip - cracked but quite easily repairable - $400
i still have quite a bit of the standard interior left, mainly door cards and anything i didnt destroy taking off while in a rage haha
UNIVERSAL PARTS
AME TM-02 wheels, 18x10+15 all corners on 1000km old achillies 123s semis 265x35x18 - all very good condition no gutter rash - $2300
power enterprise 800cc top feed injectors 11mm x 6 in boxes with plugs, new - $600
genuine greddy type rs blow off valve vgc - $100
buddy club fixed back seat, has rail to suit s13/4/5. black with grey inserts for a normal sized person, has a small tear in the fabric other than that its as new - $450
thats it for now..
please contact me on 0413347774
dash - note stack 8130 not for sale
http://i222.photobucket.com/albums/dd109/s...0821_131633.jpg
Nardi wheel not for sale
http://i222.photobucket.com/albums/dd109/s...0806_144503.jpg
alloy dash in this picture is the old version.. dont even look at it :)
http://i222.photobucket.com/albums/dd109/s...da/DSC_0018.jpg
http://i222.photobucket.com/albums/dd109/s...da/DSC_0017.jpg
Edited by spenda
Make me an offer im pretty flexible on pricing.. if soneone is keen for the whole project i will do a good deal
I can also deliver the car anywhere along the way from mackay to brisbane and maybe even goldcoast area but that would have to be arranged in one of my weeks off and will be the cost of my diesel to get there
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
