ok so the car in subject is a 1989 32 gtst
aircon dosnt work, need a bit of guidance from someone who knows more about electrics than me so i dont have to tip too much money into it
but must fix before summer hits!
ok so i have had the system re gassed with dye to find the leak, no leaks yet but the system is not yet operational. i assume i will have to replace something but thats the easy part.
the problem is my compressor and thermos are not switching on. i can hotwire it from the battery and switch the compressor on though so it does work.
i have had the pressure switch checked and their was another switch checked i think and that side of things work. i assume now that my aircon headunit itself has something broken in it, i was thinking next to just replace it and hope for the best.
is their something else electrical in the system though that i need to look at, or have looked at?
also does anyone have a wiring diagram for it?
https://www.sau.com.au/forums/topic/413008-aircon-and-how-to-fix/
Hey Glyn, do you have an aftermarket ECU ?
Quality units like Haltech or Vipec, there is a setting in these that can prohibit AC.
Likely not your problem but worthwhile being aware.
Also i seem to remember you can get a daig code out of the AC headunit.
Worth searching the forums for.
Obviously checked fuses ?
Just found many threads but this was in one of them.
Climate Control Diagnostics R32
The climate control has a diagnostic mode.
Enter the diagnostic mode by pressing the OFF button for five seconds within ten seconds of turning the ignition on.
Sensor check
Sensor check is selected by pressing HOT switch (the red triangle) while in diagnostic mode. The microcomputer detects whether each sensor input signal is within correct parameters. The results are displayed on the screen.
If normal, a "20" is displayed.
If abnormal the failed sensor number is displayed. The sensor numbers are as follows:
20 - all is normal
21 - outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
26 - PBR
27 - Refrigerant temperature sensor
This should tell you if any of your sensors are faulty
Link:
http://skylineowners...thread.php?t=47
hope this helps.
yeah i came across that a while ago, all was normal so the sensors seem to be working,
also side not i was wandering what 25 was... saw it the other day and i saw the electronics when the sun hit it and was thinking some model had auto headlights :P
all fuses are fine yup, and i have a nistune board, doubt that would do anything?
my sparky at work said he wanted to test all connections on the back of the unit and work backwards from their but thats allot of time and money, would be faster with a wiring diagram.
Fixed mine, turned out that the ecu was holding it back.
The ecu has a few states which it wil turn the ac off, most are safety related, but one of them is when you want full power out of your engine it will quickly switch the compressor off to minimise the draw.
I suspect when the nistune went in this was altered or something, mine was keeping that switch off. We rewired this so it listenes to the ac head unit not the ecu on that one. And bam Crispy cold air ready for summer
Hmmm does a Power FC do the same and prohibit the air con?
I haven't had air con for about 2 years now :(
When I first tried to fix it, I believed that it was a faulty compressor, which I had that replaced for a 2nd hand unit. Got the gas refilled, and thought I got the air con to work again as it was icy cold on the way back from the air con workshop, but after 15 odd so minutes of driving it never stayed cold and the air was like the temp of a normal fan.
I've been thinking that it's been the 2nd hand compressor all along, like maybe because it was 2nd hand the seals were brittle and cracked, so it leaked again. Never thought to take it back as I didn't want to spend more money recon'ing the thing.
But with this thread coming to my attention, could I be off the right track, and in fact it could be linked to my Power FC?
Sorry to hijack lol, but it's all relevant!
Cheers,
Andy
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
