SELLING MY R34 SKYLINE I HAVE OWNED FOR A BIT OVER A YEAR. 11,500
108,000 KM
AUTOMATIC TRANSMISSION
2 DOOR
RWC
I HAVE IMPORT PAPERS AND OTHER RANDOM STUFF (JAPANESE AUCTION PAPERS, COMPLIANCE) FROM PREVIOUS OWNER
100,000 KM MAJOR SERVICE DONE AT 94,000 (TIMING BELT, WATERPUMP, SEALS, BEARINGS ETC) DONE BY PREVIOUS OWNER
JUST DID COOLING SYSTEM FOR SUMMER, SO REPLACED STOCK RADIATOR WITH AN AFTERMARKET POLISHED ALLOY 52MM 2 ROW, THERMOSTAT AND HEATER CORE.
ALSO AIR CON HAS BEEN REGASSED AS IT HAD TO BE REMOVED TO DO HEATER CORE.
CAR IS MECHANICALLY SOUND AND WELL LOOKED AFTER, WILL BE SOLD WITH ROADWORTHY.
CAR HAS SUNROOF, NISMO BODYKIT, 18" LENSO SAMURAI RIMS WITH KUMHO ECSTA TYRES, AFTERMARKET ALARM AND IMMOBILIZER.
NISMO CLEAR INDICATORS JVC DVD PLAYER, 10" FUSION SUB/AMP COMBO, PIONEER SPLITS IN THE FRONT, AUDIOBAHN IN THE BACK (6" I THINK)
COUPLE LITTLE DENTS HERE AND THERE NOTHING MAJOR, COULD DO WITH A CUT AND POLISH.
EXTRAS INCLUDED BUT NOT ON THE CAR ARE CUSTOM 2.5" EXHAUST ( I GOT EPA'D WITH THIS ON AS IT WAS 4db OVER......) K&N POD FILTER, STOCK RIMS WITH DECENT TREAD ON TYRES, ORIGINAL REAR BUMPER, SET OF BRAKE PADS, ORIGINAL LCD SCREEN, ORIGINAL ORANGE INDICATORS.....
PROBABLY MORE I WILL EDIT THE AD WHEN I GO THRU MY BOX OF PARTS. (PHOTOS WITH OLD PLATES ARE FROM 12 MONTHS AGO) NUMBERPLATES NOT INCLUDED BUT NEGOTIABLE,
I ALSO HAVE "MYGT34" PLATES WHICH CAN BE NEGOTIATED. (PICS WITH THOSE PLATES ABOUT A YEAR OLD)
ASKING $11,500 NEGOTIABLE BUT I"VE KNOCKED BACK SOMEONE OFFERING ME $10,000 SO PLEASE DON'T WASTE MY TIME OR YOUR OWN
ORIGINALLY WANTED ALOT MORE CONSIDERING THE PRICE OF STOCK CARS WITH SIMILAR KM'S NO SUNROOF ETC ETC. SO BEFORE YOU SAY I WANT TOO MUCH LOOK WHAT ELSE IS AROUND AND HOW MUCH IT COST. CARS UNDER 100,000 GENERALLY NEED THE TIMING BELT MAJOR SERVICE WHICH COST JUST UNDER A $1,000.
ANY MORE PICS ETC PM ME AND I WILL EDIT POST ACCORDINGLY CHEERS
CAR IS LOCATED IN THE INNER NORTHERN SUBURBS AND CAN BE VIEWED ANYTIME
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
