  • Replies 193
Haha, it's been like that lately Matt :)
There is still more stuff in the post too!
Nah both for VVL Michael. The closest one to the bolting face is for the intake cam, the other is for the exhaust.
I bought new solenoids as mine are playing up a little bit from time to time. So time to eliminate the problem..
Also it's always good to have a spare.
It's good to know it looks similar to the RB25 solenoid. The GA16DE in the N15 Pulsar (non SR engine) also has VCT on the exhaust (i think), but no one has been able to confirm whether it would actually work in the VVL housing.
Also I haven't been able to find a wrecker wiling to separate with the solenoid out of the engine.
Well FAST tells me the part codes are the same for all but part #s are different. The SRVE part also appears to be exactly what you have there with the 2 solenoids screwed into the housing so there's no individual part #s for the solenoids themselves in that respect :/
Hmm, yeah okay. I could never get FAST to work with Windows 7 lol. I had it when i had XP with no worries.
The valve block + solenoids that I have are the 23796 - 1N51B so the SR16VE one (the SR20VE never came in an N15)
I knew I had to buy the whole solenoid block with solenoids, just to buy the solenoids (hence why I did).
But that's okay, I got a pretty good deal on a brand new block + solenoids.
Well the plan was to do the exhaust this weekend, but the promised parts and bends never arrived on time, trusty couriers...
That will be next weekends job now, so stay tuned.
I have quiet a few bits and pieces in the post atm, I will update once they arrive. :)
Yeah man, was the same as the run I did recently, the intake cam wasn't switching due to a dicky plug due to Scott jamming a 3mm multimeter probe up a 1.5mm hole. I've fixed it for now, Dean is sending me another plug next week.
So the exhaust is on, it took quiet a few hours to get sorted as I've never done an exhaust before. A lot of measure twice, cut once. There is still a slight issue with the catback I bought off a forum member hits the rear beam linkage. I suspected it would as my car is quiet a bit lower than his. That's not an issue atm, as the car will have to be raised a bit 10 - 15mm minimum, I want at least 80 - 90mm clearance on the 4-1's, so ride height will suffer a bit.
Function > Form
If this doesn't fix the problem, i'll pull the rear section of the exhaust off and fix it so there is plenty of clearance.
The car is ridiculously noisy, it more or less has an excuse of a resonator and a good size Magnaflow rear muffler (offset to center) I'll be buying a different resonator to put in the system tomorrow.
The top end of this car now is unreal though. Has an extremely strong pull, even more so than before. The exhaust note and rasp was described to me as sounding (exactly like a N/A 13B bridgeported rotary I built years ago) by the guy who helped me out with the exhaust.
So it's loud as f**k and raspy as f**k too haha.
Here's a few photo's anyways, sorry some of the photo's aren't great quality, it was quiet late when I took photo's of everything.
So I started machining up a prototype solid cross member bush, it's only made out of steel at this stage, though they will be similar to the ones available in the US that consist of aluminium and delrin or another nylon material, they will be like these B15 ones:
Since I didn't really know how thick to make them (since the OEM rubber was all squashed/torn) I had an educated guess. The sizing was pretty damn close. the washer needs to be 0.5mm thinner and the head of the 'bush' needs to be 2mm thicker so that the crossmember bolt doesn't bottom out on the chassis/radiator support, squashing the washer and bush to the crossmember and chassis.
Well not too much going on atm.
I'm waiting on a solid center clutch before I put my LSD gearbox back in. I'm in the process of getting my Sparco mounted up a bit better on a Bride rail for an N15.
I'm keen to buy a few more handling bits and pieces in the future, so stay tuned.
    • Every time I have to buy new tyres I question what actual difference it makes between running $40 tyres and $300 tyres and whether it's worth it. Because that's a massive difference to the wallet. But then I did go to a driving training at some point which also included emergency braking and swerving in the wet. In part I think it was meant to show people how bad it gets. Funnily enough what I took away from it is that I can go much harder than I thought in my car. I presume mostly because of decent tyres. Some of the other cars there were shocking to behold. And a bit scary that cheap tyres are probably a lot more common on the road than decent ones
    • I'm pretty sure that is just straight AI generated word soup, where did you receive that ad (facebook)? They misspell Pirelli twice, no human eyes looked at that before it was posted. Incidentally, I am running the chinese pirellis on my V37 and they are.....OK....I didn't go looking for them, they were just what the shop had in stock in the tall size that car needs. LIke any brand, you really can't trust the brand's reputation to apply to every product they produce. Pirelli make good and crap tyres, all with the same logo stamped on them, and all with an attempt at price premium due to the brand
    • Welcome.  It's unfortunate,  but a lot of these vehicles just haven't had regular and thorough maintenance for a long while. Once its back up to scratch, it should provide fun and fairly trouble free motoring.  Keep us updated with what you're doing with it.
    • Ya thankfully I've been able to drive it, it's pretty fun however I noticed yesterday while driving to work that my left side of the car is very wobbly, like any bump I go over it jolts the whole vehicle and pulls the steering wheel, I kicked the wheel a few times once I got home and it's a very distinct metal on metal clunk, so I guess I need to take a look at my suspension, maybe it's a control arm bushing or tie rod
