Hey guys, I was just curious as to why some R34 Skylines look different to the more common ones, I've noticed some of them have this different body kit on them which is stock from the factory, but whats the differences between the two R34s?
It's a bit confusing to explain, so i attached photos
The back of them seem to have a wider and lower rear bumper with mesh in it, and the front of it seems to have a red badge that is a part of the actual bumper, again with mesh.
thats the 'Altia Aero' factory optioned body kit available from from Nissan when the car was sold new
for series 1 models it also included this wing;
the Nismo kit was also availble as an option - front bar, side skirts, rear bar and wing (all of which provide functional aero);
as well as the factory option lip for the series 1 front bar;
and lastly the series 2 front bar - the below pic has a aftermarket/DIY lip by the looks of it;
oh wow, never knew that. thanks heaps.
just wondering, the car in the photo i posted, does that mean its a series 2 R34?
and is this kind of car a lot rarer? or common? or any information on the differences on the car i posted would be awesome
they arn't rare moreso less common than the factory standard front bar - as customers would have to pay a premium for anything other than the standard bumpers;
the Altia aero option was available to the later series 2 models, the only way to tell would be;
- no 3-piece wing, series 2 models were offered with the standard wing
- series 2 interior;
- 2 tone steering wheel with emblem in the center / gear shifter, silver faced dials, aluminium drilled pedals
- series 1 interior;
- black only steering wheel with 'Nissan' embossed and black gear shifter, dark faced dials, black rubber pedals
Edited by squareznboxez
okay, i get that. but it gets a bit confusing because,
the car i posted the photos of has the standard wing, and you're saying that means its a series 2?
yet the interior of it is more like the last photo you posted, the exact same interior almost, except it has the 3 gauges like boost etc.
so from this, the photos of the black car i posted, is it series 1 or 2? considering the interior is exactly like the last photo you posted
http://i994.photobucket.com/albums/af65/squareznboxez/frontinterior-1.jpg
http://i994.photobuc...tinterior-1.jpg
that seems to be a non turbo and also auto by the looks of your steering wheel? Seems to be a S2 from the colour scheme inside.
Edited by darksky34
for the spoiler, both the 3-piece and standard spoiler were available with the the series 1 cars, where as the series 2 was only offered with the standard spoiler
if your interior looks like the last photo, its a series 1 model with the altia aero kit with the standard spoiler
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
