THE LAST DECA OF THE YEAR.
AND ALWAYS THE BIG ONE...
So once again we ask for your assistance
For this event to run SMOOTH on TIME and SAFELY we need a small group of volunteers (Officials )
to help run the day. With out the help of volunteers we can not run these days.
Officials are needed in 3 sections in the morning and 1 section in the afternoon.
All Officials on the day will be supplied with drinks and lunch.
An Officials breifing will be held before the Drivers breifing so all volunteer Officials will need to
be at the DECA complex by 8.30 am on the Saturday morning the 8th December
So if your thinking about coming up for a look and not competing this is a great way to get up close
to the action.
Also if your competing and bringing a friend or 3 it would be great if they could put there hand up
to help out on the day.
So if this sounds like you or your friends post up in here or PM me and i will will put you on the list.
Cheers WayneO.
MORNING
SKIDPAN
STARTER...Wayne ..RCHOO
TIMMER......Clive
FINISHER....Damian
MINI WANG..?
STARTER.....Campbell
TIMMER.......Kieran
FINISHER.... Daniel
MARSHAL...
LONG WANG
STARTER... Anna
TIMMER......Luke
FINISHER....Trent
SPOTTER 1 ..Stuart
SPOTTER 2..
SPARE..
AFTERNOON
SKIDPAN
STARTER.... Wayne.....RCHOO
TIMMER........
TIMMER,,,
FINISHER
FINISHER
https://www.sau.com.au/forums/topic/413259-deca-officials-volunteers/
I think there would only be a few stops left on the entry list or if not already full.
I know we have 1 motel booked solid and another filling fast.
So unless we get volunteer officials this will all be a waste of time..
So lets go people .
to the action.
Cheers WayneO.
MORNING
SKIDPAN
TIMMER......Clive
FINISHER....Damian
MINI WANG..?
TIMMER.......Kieran
FINISHER.... Daniel
MARSHAL...
LONG WANG
STARTER... Anna
TIMMER......Luke
FINISHER....Trent
SPOTTER 1 ..Stuart
SPOTTER 2.. Michael
SPARE..
AFTERNOON
SKIDPAN
TIMMER........
TIMMER,,,
FINISHER
FINISHER
It still would be nice to see a few more people putting there hand up to help.
can never have enough incase some dont turn up..
Cheers Guys
Not sure if Bec has talked to you about me? As I've not heard anything from her.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
