hello SAU.
i've just brought my first car, a skyline of course. I've had it for a year now with litte problems. although its only a stepping stone for my skyline I take alot of care maintaing it as best i can with my engineering and servicing experience.
its a r33 1997 gts25 import with 180000ks
recently after returning from overseas my car has had a painfully rough idle and warm start up issue only below 2000 rpm. the engine feels as if its missing or almost stalling randomly at any stops especially. i was attempting to replace the gaskets and polish the head lights and foggies before i started it the first time. so i cant tell if its something ive done or its happened while i was away. when it was being started and driven once every 2 weeks. i took out the coils and plugs, cleaned and inspected them while sealing all the valve cover everything seemed fine.
i've tried everything ive reasearched so far and nothing seems to work it has no fault codes. i cleaned the AAC and the MAF but found no change. the plugs and coils seem fine only one with a small crack in the ceramic and another coil with some oil on the outside of the boot but no noticeable firing issues. i do have a power steering leak and it moans when its cold. hence the AAC check.
Please help cheers!
i was out for 4 months but i had realitives starting it and driving it small distances, i had driven through the last quater tank that was left in it and just refilled it but the problem is still happening. could it be a injector?
okay so i changed the fuel filter, and the plugs still going. i poured in a whole bottle of injector cleaner in the tank and its still going for it when im at the lights. im starting to believe its the torque converter.
so i put a bottle of the auto trans fluid in and it seemed to make it worse if anything.i rememebered a while ago just before i left i dropped a shattered end of a screwdriver down the back of the the intake valve cover i was too frustrated with the screwdriver and finding another one i forgot to get it out. I was thinking maybe just maybe it has somehow slid down and is causing the torque converter clutch to slip between free and engaged please tell me im a complete idiot and its something much simpler and this is impossible.
It sounds like you need to take it to a mechanic. For starters, have them drain all the extra trans fluid you put in so it didn't damage the gearbox (you can't just put in a bottle of fluid if it doesn't need it).
Secondly, unless you had the gearbox off at the time, the screwdriver wouldn't get into the torque convertor.
Thirdly, you should only use injector cleaner at the recommended dosage, and it won't just magically fix any problems straight away. It will take most of the tank of fuel to do anything, but those injector cleaners don't do much. You are best off having the injectors professionally cleaned.
i meant the transfluid conditioner stufff which told me to put in a whole bottle. and same with the injector cleaner it reccomended half a bottle to a tank but strictly said overdosing will not affect it at all.
but im determined even without the screwdriver its still the torque converter im going to take it in soon. thanks
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
