Hey guys
So my coils are causing serious misfiring problems and jerking at WOT in my r33 skyline gtst s2
Alternatives are either yellow jackets for $420 or Splitfires for $600
A bit out of my budget and have seen the Fuji Spark's for $250, has anyone had any experiences with them? Not looking to get more then 220rwkw out of this car.
A bit wary of going cheap as the last time I took the cheap route with performance parts it bit me in the ass
Link to said coilpack:
Fuji Spark Coilpacks
Thanks in advance for any long term experiences with these coils
https://www.sau.com.au/forums/topic/413573-fuji-spark-coilpack-review/
any other experiences with fuji sparks?
if it comes down to it il get yellow jackets , splitfires are overkill for my purpose - daily driven with a goal of 220rwkw
Many go for splitfires for reliability - not because of a perceived performance limit. If you're not going with OEM or splitfires, then I suggest you buy from someone local, so its easy to swap if any of them are defective.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
