here is the quote i got from Garage 7 to build a "reliable RB25/30 RB32 450rwkws"
still need coils and others little thinks too
parts price Nitto 3.2L stroker kit $6,500.00 Nitto RB series high volume oil pump $1,449.00 Oil restrictors $40.00 Moroso 1.5QT oil accumulator $295.00 Moroso oil accumulator mounting bracket 1 45.00 45.00 $45.00 Moroso inline electronic solenoid valve $155.00 Speedflow -10 AN 100 series braided hose (sold p/m)(100-10) 3 x $37 $111.00 Speedflow 1/2" NPT to -10AN male flare (816-10) $11.50 Speedflow -10AN male flare t piece x2 w/ x1 female -10AN swivel (145-10) $45.00 Speedflow straight -10 AN 100 series braided hose end (101-10)$20 x2 $40.00 ARP Nissan RB25 head stud kit $240.00 Permaseal MLSR head gasket $260.00 GARAGE 7 steampipe manifold $1,500.00 Plazmaman RB25 inlet plenum in silver powdercoat with 72mm TB $1,520.00 Camtech CTRB20 426A (a) camshafts - 272 adv duration/9mm lift $890.00 Camtech valve spring and titanium retainer kit $770.00 Ross Performance crank / cam trigger kit - includes Metal jacket balancer, crank trigger, cam trigger, x2 hall effect sensors, cam & crank sensor mounts $1,957.00 Powerflow blueprint 1000cc flow matched injectors w/CNC extrusions, plugs and adapters $660.00 Powerflow Nissan RB25 billet aluminium fuel rail $299.00 Powerflow 2 port high boost fuel pressure regulator (suitable for 900HP) $268.00 2.5L fuel surge tank $110.00 Holley 12-1400 dominator fuel pump (-10AN o-ring ports) 105gph @ 60 psi $399.00 Link G4 Xtreme ECU with A+B looms $1,750.00 SPR 3 bar map sensor $65.00 3 port boost solenoid valve $50.00 Garrett GTX3582R w/ 1.06 a/r turbine housing $2,500.00 Synapse 50mm external wastegate w/ flanges and clamps $450.00 Total $22,379.50
whats everyones thoughts oon the parts i got quoted
Edited by MRHD66
https://www.sau.com.au/forums/topic/413819-rb32-450rwkws-quote-from-garage7/
they'd be putting mark up on all the parts. Thats what you do when you own a business. If you did some shopping around yourself for parts, you could save some cash, but then some workshops might not like that.
so they are not even offering you any discounts on any parts after spending over 20k with them?!
if I was to get everything at once I'd get 10% that figure but that won't happen as I don't have a spare 20k just sittin there
yeh that's my thoughts exactly goin to use This as a guide and see if I can get these parts cheaper
straight away i can see things u can save some serious coin on, oil pump turbo fuel rail etc mabe try getting a similar quote from a few other work shops ? i know i got my motor built and it didnt cost no where near what i thought it would because i shopped for the parts and the workshop looked after me because we has spent so much there
cheers mate I will when i get some more cash
id get a t04z with a .82 rear housing and smaller cams and convert it to e85
I don't wanta convert to E85 with smaller cams will I still make 450rwkws on smaller cams with a gtx35 on pump 98 or 100
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
