Guest Robo's
Ok, after i tuned my R33, and now driving around for a few weeks i've found im getting a flat spot in the power curve. It has exceptional strong mid range and top end (6000-7000) but i notice ive got a dead spot around the 5,000 mark. Like mid range is strong, then it goes flat, and then strong to redline. Overall im kicking out around 210rwkw which feels strong, but i feel if i can get that flatness out i would be happier even more. Im only tuning it with a SAFC, i havent started playing with timing yet although i reckon im on the mark as it used to ping with the stock cooler, not so with the FMIC.
Any thoughts?
https://www.sau.com.au/forums/topic/41419-rb-25-flat-spot/
The best way is to get it properly checked on a dyno, and the tuner can enrich/lean out your mixture with the S-AFC in this range, depending what its doing (the only way to know is to get it properly checked).
Another cheaters way is to undo the bolts to the crank angle sensor and turn the housing a few degrees (so you can just see where the old bolt mark was) and tighten. This advances the timing slightly, it gave me an extra 12rwkw when I did this on the dyno.
Good luck.
https://www.sau.com.au/forums/topic/41419-rb-25-flat-spot/#findComment-850811
Have you checked your airflow meter reading on the AFC? Mine hit 5.115V at around 4.5-5k rpm with 200rwkw, which wasnt a problem until I got a cold day. Net result was detonation on colder days - perhaps you are leaning out and the ecu has pulled some timing.
If it was a one off occurence, it is possible the ecu has pulled some timing in that range - how lucky do you feel:)
Best bet is put the car on a dyno where they can check. Even if a tune was done 2 weeks ago, a cold day and you are in trouble when you tune on the edge.
https://www.sau.com.au/forums/topic/41419-rb-25-flat-spot/#findComment-850875
Guest Robo's
She is not pinging at all now, i havent heard it ping since installing the FMIC, which makes me think some more timing could go in. But with the stock cooler, i used to get some ping up high and i havent adjusted the timing at all, just the A/F ratios. A/F ratios are as good as we can get with the SAFC, between low 11's and high 11's. We can never get A/F ratios to be nice and steady due to the limitations of the SAFC, but we are trying hard.
https://www.sau.com.au/forums/topic/41419-rb-25-flat-spot/#findComment-850961
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
