Okay i have read the sticky but nearly all that is attaining to the rb25/30 combo..
i have a gtr i want to put the rb30 block in i have the block i know how to do the majority of the work..
QUESTIONS
1) Can i use the rb26 harmonic balancer?
2) if i use an r32 oil pump do i have to fit the jun or tomie crank colett thing? or is it easier to use r33 if so where do i order these from nissan only has part numer on r32?
3) what pistons should i use rb26 ones, i will be goin forgies, plus i am using scat h-beam rods, is that all good?
4) i understand the gtr sump doesnt fit straight on any ideas on what has to be done apparently a 10mm spacer girdle has to be made?
5) it 750 hp safe and what revs can i make i want at least 7500rpm-8000rpm (due to the cams i have already), sub zero say its cool for 8500+, not sure bout that... i will be going the best assembly i can ie. crack testing, o ringing, cross drilled and balnced crank.. do think its all possible...
6) apparently my bonnet wont fit on due to the extra 30mm from the rb30, anyone know for sure... can i modify the engine mounts to get it sitting back down????
Sorry for all the questions, thanks in advance for any answers i really appreciate your wisdom on this...
Daniel
https://www.sau.com.au/forums/topic/41434-technical-questions-on-rb30rb26-gtr/
Daniel,
Here goes.
1) Yes you can
2) Use a R33/34 oil pump with the collar
3) You should use RB26 ones and set CR to 8-8.5:1
4) There are a couple of ways to make it fit
5) 750Hp is easy and i assume that at the crank, the rev should be kept as close to 7,000rpm as possible. unless you are building a race engine
6) If you lower the engine you will have sump clearance issues just cut a hole for the front of the head to fit through the bonnet and get a bulge made similar to the BA XR8 ones
I am curently building an engine like this but to a much higher level is you need some parts ive got some spares email me [email protected]
Or ask any questions
Jordan
cool thanks for the quick reply still more questions though
2) where ca n i get these oil pumps??
3) do you have any new forgies???
4) What are the way? was i on the right track???
5) it will be a race engine, hardly ever driven on street
6) no way cutting a hole that looks homo, must be something i can do??
Currently
Clevite h series bearings
arp main bolts and head bolts
scat 4340 h beam rods
je forged pistons
floating gudgeon
mods to sump amd head oil galleries
a few other things but thats general, it will be pretty full on but not to your level descr8
2) Nissan have them
3) Yes ive got a new set of JE 87.5mm that were going into my previous build but i decided for more HP so went to 86mm pistons. Emal me if you are keen on them
4) Yes whos building it for you ?
5) Well if its a race engine whats your budget?
6) Go a dry dry sump have a low profile sump made and then have custom mounts made like i said whats your budget?
Jordan
im buildin the engine, i wanted to keep the parts list budget under 4 grand, that is not including machining and so forth but with rods only being 1200 and hopefully the pistons around the same i dont see why i cant do it...what are your thoughts??? I really dont want to go dry sump 1 due to the expense, i know how great it is and all, and 2 due to it will be more drag work than circut... my budget doesnt go on forever id be happy if i got out of it all inclusive for around 6..that include me doing all assembly, prep, install ect ect
Well i havent finalised what shell my engine will be going into but if it is a 180SX or S15 thats the only way i can see of fitting a RB25or RB26/30 under the hood without cutting a hole.
Well those rods you have are for a V8 and i think are rated at 800 for the 8 which means that works out to 600hp for the six you will be using. I would recommend and Argo or Eagle rod to suit they are more expensive but i know they will hold up having said that im not saying the scat wont just had no experience with them. My pistons are worth and cost me more than $1200 so unless you are after a top shelf pistons with top ring set i cant help you. Just remember you are aiming at making 800hp from six cylinders which is 133 per cylinder a v8 only has to do 100 per cylinder keep that inmind
Jordan
yeah thanks mate, i really appreciate your input.. I understand the pistons might be a bit more it was more a stab at finding out what you were selling for haha... id be really happy with 700-750 hp at the crank that said it is nice if your engine does that with head room for more.... i was told buy a reputable supercharging company in oz that they have seen scats in many supercharged and turbocharged v8's doin 1000hp at the crank... going on cylinder pressures rpms i am willing to trust that the scats will be safe for 800hp???
Please more info needed on this girdle i have to make???? pretty please
I will work out something in regards to bonnet clearance theres no way im having a hole or massive bulge.....
thanks again
Well the pistons with Total seal rings owe me $1800 so offers close to that will get them they are brand new, and will be perfect for your HP Levels
As far as my engine having room for more i am going for broke on this engine so i will give it all it takes and hopefully not too much ;):):(
Jordan
im unsure on eagles specs but scats are 4340 chromoly same as carrillos, are machined and balanced with 1 gram of each other same as carrilos, and come with arp 7/16 2000 non replacable bolts same as carrillos.... i know carrillos are better but for an option thats half the price they stack up pretty good... best h-beam value for money i can find....
Scat have been around for ages doing pretty good work, they primarily do circle track parts which is constant high rpm levels, and alot of the classes require lightweight stuff to really accelerate hard out of the turns. I was checking out one of their lightweight big block chev cranks yesterday, was an absolute work of art. I liked it that much I actually made a serious enquiry about the price ($2500 2nd hand)... but wtf am I going to do with it?
Eagle is a relatively new company with products aimed at the budget end of the spectrum - although in saying this most applications would be well within their limitations.
It's harder to be an innovator of products, rather than mass producing a copy of others.
Edit: Although I find it hard not to giggle a bit everytime someone mentions "scat"
hey Sydneykid, what do you do in relation to the taller engine do you cut holes in bonnets???
also i need some more advice on the girdle thing i have to make for the sump is it just a spacer??? if so will 6mm be enough???
Also are there any oil gallery/restrictor stuff i can do?? im goin to reduce the size flowing up to the head any other suggestions???
thanks again ppls
what water pump pulley should i use as the rb26 and rb30 are different.
hopefully some of you other guys that have done the swap or even done the rb25 swap can help me out....
  • 11 months later...
so dosnt the std r32 gtr oil pump fit the rb30e's crank? or are u jsut suggesting this as a upgrade?
i am building a rb30/26 running a t88, these are them pumps i have whats fits and whats best?
r32 gtr std
1992 rb25de
2x rb30e std (remember they are hydrilic lifters so should supply enought for solid rb26 head,
what 1 should i use?
r32 gtr std
1992 rb25de
The RB30 cranks have the same diameter (small) at the oil pump flange as an R32 RB26DETT/RB20DE/RB20DET/RB25DE. The R33 and R34 RB26DETT cranks have a larger diameter at the oil pump flange, so you need a collar if you are using one of their oil pumps on an RB30 crank.
I would use the R32 RB26DETT oil pump, just check its tolerances and the pressure relief vlave spring rate carefully.
:P
thanks again ppls
Uhhhh..... s13drifter, I am CONFUSED!
On the bottom of your sig you claim to have the very plate you are enquiring about as if you know nothing about said adapter plate.
This is what you pm'd me a few weeks ago...
Hi Greg,
No long term testing has been done but i really cant see where any problems could occure, I have seen how others have done and know mine is a far superior way of doing it, and Nizpro had their circut version going i think for around 3 years. THe plate is 10mm thick and is a high cadium/nickel mild steel whick doesnt rust like normal mild steel... With your combo there is a little work getting it under the hood but talk to people like Cubes who have done theres, my plate only adds 10mm towards the crossmember anyway so its not as if you have to worry about the motor sitting higher than any of the other rwd boys doing the conversion. If you have any further questions let me know.
Regards,
Daniel.
Maybe you would like to enlighten me(/all of us) on this because I was seriously going to consider buying said adapter plate from you.
Hi Greg,
Regards,
Daniel.
Daniel is looking at making a full crank girdle incorporating the 4wd adaptor plate. This is a step up necessary in strength for over 1,000 bhp from the RB30 standard crank and block. The last time I priced one it was over $3K. So if Daniel can have it designed and made for a competitive price (like he has for the 4wd adaptor) it is a big step.:P
I use all the pulleys off the same engine, ie; if I use an RB26 harmonic balancer, then I use an RB26 water pump pulley, an RB26 power steering pulley etc. If I use an RB25 harmonic balancer, then I use an RB235 water pump pulley power steering pulley etc. You also have to use the same brackets as well in some cases, as they are different. :rofl:
I have NEVER had a problem with "taller" engines. The cross over pipe on RB20/25's being 75 mm, is much bigger in diameter than the 28 mm an RB30 block is taller than an RB20/25/26 block. Plus the engine mounts have more than enough meat on them for redrilling the holes in a 2wd application. The sump doesn't extend down past the radius rod mounting sub frame, so there is no reduced clearance.
As for 4wd, the first R32 we did with an RB30/25 had a Sub Zero plenum on it, plenty of room and it had a thick strut brace. The current RB30/26 going in the R32GTST clears easily with the standard RB26 plenum. The last RB30/25 had a Greddy inlet manifold/plenum and a strut/master cylinder brace and it fitted in no problems. There are plenty of GTR's around the world with OS Giken 3 litre kits and they are only a few mm shorter than an RB30. Most have high mounts too.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
