Bernie negotiations 101...tell teh media it isnt going to happen = generally means the opposite. Fingers crossed he will be in gaol soon enough and his daughters pedalling their a55es on street corners to pay the rent....and France and real F1 markets get/keep their GPs!
I think it will be sad to lose the Indian GP. More than Malaysia I think give it a few years and there is a real interest in motorsport and F1 that will see the continued bums in seats. Singapore, India and Malaysia...and then Australia and Japan are enough. Nobody in China or Korea give a rats a55 about F1 so dump em...
the promoter has come out and said it isn't going to happen in 2014.
http://www.autosport.com/news/report.php/id/109106
It would be good if all the Tilke designed and modified tracks were stricken from the championship.
Make the rules so the cars are not as gay as blowing two dicks at once.
Cap the aero and actually make the sport interesting again.
Any drivers who complain about safety etc etc should have the opportunity to quit.
There are atleast 103394385974985345734897593487534897598475 other capable drivers to replace them at at 10th the price.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
