Bernie negotiations 101...tell teh media it isnt going to happen = generally means the opposite. Fingers crossed he will be in gaol soon enough and his daughters pedalling their a55es on street corners to pay the rent....and France and real F1 markets get/keep their GPs!
I think it will be sad to lose the Indian GP. More than Malaysia I think give it a few years and there is a real interest in motorsport and F1 that will see the continued bums in seats. Singapore, India and Malaysia...and then Australia and Japan are enough. Nobody in China or Korea give a rats a55 about F1 so dump em...
the promoter has come out and said it isn't going to happen in 2014.
http://www.autosport.com/news/report.php/id/109106
It would be good if all the Tilke designed and modified tracks were stricken from the championship.
Make the rules so the cars are not as gay as blowing two dicks at once.
Cap the aero and actually make the sport interesting again.
Any drivers who complain about safety etc etc should have the opportunity to quit.
There are atleast 103394385974985345734897593487534897598475 other capable drivers to replace them at at 10th the price.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
