Hey all.rb20det got mines computer,r33 series 1 turbo,rb25 afm,3 inch exhaust fmic,boost at 13.5 psi gtr 32 fuel pump wired for 13.8 volts.my question is can i update the ceramic wheel to steel and wind on some more boost and will my injectors keep up or am i better off getting another turbo if so what type,,,im a bit over lag but i love the hit up high..are forward plenums a waste of time for a rb20..thanks in advance..
https://www.sau.com.au/forums/topic/414484-rb20det/
No you cannot just shove another turbo on and wind up the boost.
1. Get rid of the MINES computer
2. Get a Nistune
3. Then do a turbo, injectors, Z32 AFM upgrade
4. Forward facing plenum gives almost next to no performance benefits if any. Some say they lose power and torque. Make your engine bay look better yes.
5. Skids
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642028
Forward facing plenums do give some perfomance advantages, you reduce the heat generated at the top of the engine bay due to the intake intercooler pipe.Also shorter pipes means its a bit more responsive since it doesnt have to bend and travel twice as much just to get into the cooler. id agree with everything else kitto has told you.
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642093
what exactly is a nistune and who can do it around the blacktown area.nsw. do i need to pull my mines out and put the stocker back in and will it still run.dont know too much about the history of the car...
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642121
she runs really well atm.bit of lag,have a manaual boost controller under the bonnet was wondering how it would go if i screwed the boost up maybe to 15psi...?
Nistune. Your at risk destroying your engine as it is. Just because it runs 'well' doesn't mean the AFR's are in check.
MINES computers are known to not have good tunes in them to suit Australian conditions.
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642127
how much do i need to spend to get a reliable afr meter and what brand?
Just get a tune dude. Nistune and get rid of the MINES computer!
An AFR gauge is not going to help you at all, none, zip, nudda. Factory 02 sensors are narrow band. If you hook up an AFR gauge to it is going to give you nothing but false readings all day every day.
The only way to have some what of an accurate AFR gauge is to use a complete wide band setup.
But thats besides the point. You need to ditch the MINES ecu and get a re-mappable ECU and then have it tuned.
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642153
Yep - searching always helps :)
You'll find that @ 7000rpm and the airflow going on - that really is not a major factor in a road car when using its performance.
Peak hour traffic, yes, but performance has no place there.
https://www.sau.com.au/forums/topic/414484-rb20det/#findComment-6642229
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
