Just had my V up-rev tuned, 227.3 rwhp (169 rwkw) before tune 245.1 rwhp (183 rwkw) after. Pulls alot harder especially mid range, revs to 7000rpm and still has more go but a bit cautious to go any further. The up-rev tune was done by PZP in Perth. $550 :thumbsup:
  • Replies 96
Posted Images
So worth it hey. Couldnt believe the improvement in torque and response.
i notice it most in mid range, from 80k's up it seems to just get stronger. 2nd gear 110km/h @7000rpm and still had some stick....but was cautious to go any harder. Fully recommend for any one interested in squeezing all they can from a N/A engine :yes:
Hey Gerard, what mods have you got?
Hey xj265 Z tube, K&N high flow filter in stock air box, MD 5/16 plennum spacer, throttle body spacer, Y pipe stock cat back, transgo shift kit, Lovells springs, Kinetix full camber/traction kit and now Up-rev tune :D
Thats complicated! First run was 166rwkw without a tune.
My ECU didn't seem to like Uprev; it had a Master rom version they hadn't seen before so its with Uprev to get it sorted.
Hopefully will be sorted before the new year :)
  • 3 weeks later...
I'm stoked! This is with the cheap and nasty compliance air filter and cats (that are mismatched).
Mods to come: replace awful y-pipe/cats, new air filter.
Current mods: Motodyne 5/16 spacer, Rev up air box, stillen z-tube, JIC Magic Spartan DE Catback, chinese y-pipe
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
