I seriously almost stuck my car into a tree I was laughing so hard when I saw chookie pop out the roof of your car.
was it really that funny?
was farking sweet riding like that though, did anyone get a pic? ha
  • Replies 110
Posted Images
Alright I'll forgive ya but yo better be at the next one
I was behind Kurtis for a while and you will lose that battle
Damm fine car that, fast and reliable
Although since Chookie worked out how to use the sunroof in my car he reckons I should be the official photographer car
Oh thank you for kind words , next time feel free to jump in for a ride.
shot guns first ;) had a great day even know my young blokes guts couldnt handle the corners and had to stop twice for a spew.the food wasnt much chop but still had a good time.was good trailing behind the ethonol burners and after my cars new turbo setup it ran great.cant wait for the next one
Hope he gets over that real soon.
Is a pity he can't handle the twisty stuff at the moment, might have to get Chookie to mak an easy route for the next one
i think next time we will let him hang with his pop for the day.
the r33s must not be worthy of any pics :rolleyes:
There is a pick with mine in it at the pub car park,where did you park?
So embarrasing i was trying to reverse on the grass and kept spinning the wheels,
then when i was leaving same thing in the gravel.
He was parked down from mine
Had the same drama on the grass as well
On a different note glad you got the idea coming back up the freeway, don't think the guy in the RAV4 was to happy with me though
How bout that nice 32r that went past us then turned round and cruised up the f3 with us.
He came up beside me i looked left got a nice smile off him an his passenger,hope they checked out our sau stickers an get on the forum. :woot:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
