  • Replies 110
Posted Images
Any more pics
I missed all the hair buns by taking my short cut back home Because just got way to warm in the bitch
Argh I want to go hit some corners now
Ye I have a few more on Beks camera . Ill try get a hold of it and post them up later :)
Just wanted to also say not only was the cruise good but the company was even better. Couldn't think of a better bunch of people to go on a cruise like that with. Cant Wait for the next one! :D
Ditto,these newy peeps are awesome to cruise an chat with. :woot:
To the freeway for some high boost
Should never be OFF high boost!
Except for Mat.
He touches me.
Inappropriately.
:yes:
Would be rude not too!
So i wasnt on the cruise but i WAS around some skylines, i missed a pic of the 34GTR Targa Tasmania car... It was sexy time!
I wont be missing any future cruises and i will have my +1 with me at all of them from now on :woot:
Sorry, no can do, I got work remember?
:( Wheres the love man??
Oh and these 2 guys cruised with us and did some drag racing haha
Old school skylines!
Mat wrap up threads are for people that attend!
Gtfo! Whtshhhh Whtshhhh!
Josh he means you need to GTFO too :P Assemble the whores and overrun this joint!! lol
I attended, i was just at the wrong meet point.......... In VIC haha
This thread needed more pics so i decided to assist!
And you WOULD have had another 34 attending if you didnt leave him behind, what happened to "never leave a man behind":P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
