Has anyone got any 32 GTR dash vents? i need the left one and the center one... As mine have both fallen apart. Also how hard is it to replace the dash in the GTR? is it an easy one or is it pull almost everything out of the car?
thanks
https://www.sau.com.au/forums/topic/414854-r32-gtr-dash-vents/
I TRUST YOU RICHARD! I'm Just looking at my options atm.. I have NO money due to this rebuild breaking my balls. But when i get the car back and have a bit more moneys i want to fix the A/C and the bubbled dash. When those are done im all good... Interior wise i have 1 small bubble and the cracked vents. All seats look new.
Oh also need to replace the ECU... Verms needs to hurry up and sell me his Apexi.
hey mate It can be done without taking the dash out if your vents are already broken you can remove them with the dash still in place, just be very careful when putting the new ones in :)
ignore that if you are planning to replace your dash just do the vents then :)
Thanks mate yeah thats why i was thinking if its hard to take the dash out ill wait till my motorbike will be back up and running as when the car is back ill be taking the bike off the road to do a full respray haha. Hence my thoughts where just to get new vents and take them back out when i replace the dash. Still deciding.
Its more waiting for you to give me $$$ for it!
  • 4 weeks later...
Yeah - if your replacing old and there broken you can pull them out and just push the new ones in.
But be aware that the vents are screwed on from the back of the dash
Hey fellas just trying to put in a new centre vent in my 32... but it doesn't want to push in from the front even with a bit of force
Sinista, what do you mean that they are screwed in from the back? I can't see any screws in the new vent? or is there a bracket that screws into the dash from the back that holds in the vent?
Can i get it in from the front without removing the dash? is there some sort of technique that'll help?
I read somewhere else on the forums someone said "look inside them and you will see tabs which you put a flat screwdriver into and lever down. Its a lot eaiser than taking the dash out."
any help appreciated. cheers
My centre vent fell apart yesterday.. finally... they have tabs ontop and underneath them. but since mine was apart i could just pull it out, bit of glue for not and shoved it back in haha
Sorry about not sending Pics. Hit the turps early otaday and just got home.
EWill do it tomoz.
Edit: And Anthony when wouold you like the Dash for cash ?
Will have another available soon. Because my brand spanker is turning up mid to late Jan :D
well i need to see how i am with cash after the ECU, Injectors, boost controller and tune are done. if im all g ill grab it off you then... whats the go with those ID injectors you have?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
