Anthony - come pick the dash up and pay later (i need space)
As for the vents - if your going to replace them just pull them out.
Centre one has 4 clips top and bottom, Passenger has 2 clips top and bottom.
See pic.
Newies will slide in and clip into place.
The screws I saw previously just hold the AC/Heater plastic piping behind the vent to the dash. Dont actualy screw into the vents.
My pics comming tomoz
yep that would be a bonus Anthony.
Just need to be certain you take the ones for the stock fuel rail and I keep the aftermarket fuel rail ones :).
Should be easy to determine.
Call me on 0408 732 655 when you get to the pine Island turn-off :thumbsup:
I have a set of fairly new vents in the car (bout 1 year old) i sort of dont need them anymore as the ducts are not hooked up anymore.
The only problem id have with selling them is what do i put in the holes in the dash? i cant think of anything easy that would look ok.
If you have a solution ill sell them to you cheap.
Brand new ones out of the box are better so do that if you can afford it. Like in Sins pic you can see the plastic bag, fresh produce!
lol - I dont usually answer an unknown number when getting sex. However it all worked out.
Thanks for helping clean up my garage :) You have a very nice GTR there :thumbsup:
Actually you interupted my BLT in the garage. Phone was in the bedroom :(
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
