Hi Selling my very loved R32 Skyline as i now have wayyy to many imports.
It is very clean and had a respray jsut before i bought it a few years ago.
It hasnt had much road time since i have owned it as I was always been upgrading parts. Have done pretty much 90% of installing the parts/ Engine with a qualified mechinac. All enigne parts have done about 5000km all up.
Very quick R32 and is due to be in High Performance imports Magazine in January/Febuary.
Ran 12.4 @ 125mph with crap tyres so was hard to keep traction. With some wide semi slicks should be much quicker.
Got tuned recently and got 440.1rwhp (about 330rwkw) @ 19 psi by High Tech Tuning on a safe tune so has much more potential to get over 500hp.
Engine was Built my Engine worx in winchelsea.
Engine :
RB25DET Conversion series 1
Forged internals
ACL Race series forged piston kit
Forged Eagle rods
Assorted gallery plugs & specialty sealants
New engine parts kit (Bearings etc)
Grind crankshaft
Dismantle/ degrease and inspect long engine
Bore and Hone block
Recondition head
Ported and Polished Head
New water pump
Dismantle/ clean/ inspect oil pump
3 layer metal head gasket
Hone rod bushes
Balanced inline engine assembly & align rods
Series 2 CAS+ loom
Front mount intercooler
Plazmaman inlet plenum
Garrett T04Z Externally Gated Turbo 0.84 rear housing
High mount Blue mild steel manifold
Braided oil/water lines
Tomei Adjustable cam gear - exhaust only
New Timing belt kit
3.5" Strait through mild steel turbo back exhaust
Splitfire coil packs
Nismo engine mounts
Working air-conditioning, just re-gassed
Fuel System:
2L Surge Tank
Bosch 040 Lifter
Twin Bosch 044's to engine
All Braided lines in boot
Custom twin feed fuel rail
750cc injectors
SARD fuel pressure regulator with pressure gauge
Driveline:
RB25DET Gearbox - custom gearbox mounts
Royal Purple Oil
Brand New Jim Berry Full Monty Clutch rated to 1000hp
Braided clutch line
Custom driveshaft
Shim-locked diff
Suspension:
BC Motorsport Coilovers
HICAS lockout bar, Hicas system fully removed
Solid rear cradle spacers
Majority of suspension bushes replaced
Electrics:
Apexi Power FC Computer
Turbosmart boost controller
BEE*R Rev limiter modified for launch control/antilag/flat-shift
Body:
GTR body kit with recent respray
Tinted windows
Tinted Indicators and Tail lights
10000k HID Lights
Carbon 'look' boot (Can be taken off easily - did have to match Carbon hood)
Drift tech wheels 17''.
Pioneer head unit - 6'' speakers.
Has GK Tech Deep dish steering wheel.
Drift Button.
Looking for $17,000 firm - have spend so much more than this on the car but have other needs now.
Might be interested in swaps for a 4x4
Just put 6 months rego on it
Text me on - oh for free ayt ayt free fife too too for -
Located in Darwin NT
No test drives without a serious deposit.
  • 1 month later...
  • 3 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
