Hey guys, i have a heap of parts left over from my wrecking of my r34 25GT coupe. Here you will find a lift of parts that i have, pics can be attained by PM. These prices are not set however i will not sell them for an unreasonably low price.
Rear bar - 200 ono (sonic silver) - pickup only
Rear reo - 150 ono (pickup only)
Front Hubs with disc and caliper 120 ea pickup only
coolant overflow tank -40 ono
Stock wheels full set, 16 inch. light rash on all fours. with 2 pirelli p7 tyres on 90% tread and two cheap supercats on 60% 450 ono - pickup only
doors and mirros - both have light dents asking 350 ea complete ono - pickup only
back seat - 60 ono pickup only
front seats - 250 pair ono pickup only
drivers side front guard dent on top of guard otherwise immaulate 100 ono, pickup only
stock suspension 150 ono
floor mats 150 ono
glovebox 60 ono
strutbrace 40 ono
tail lights 250 for set ono
interior lights 30 eachc
entre console 110 ono
clutch master cylinder 120 ono
brake master cylinder 120 ono
sun visors 20 each
wiper motor 50 ono
abs unit 150 ono
wiper and blinker indicator switches 50 ea ono
steering colum garnish 40 ono
cluster 200 ono 124xxx kms
cluster surround 40 ono
primary shift boot 20 ono
brake pedal bracket 50 ono
N1 coilpacks 200 ono
driver and passenger doors 250 ono pickup only, some very light dents and mostly complete pm for details
https://www.sau.com.au/forums/topic/414948-r34-part-out/
UPDATE
floor mats 150 ono
glovebox 50 ono
strutbrace 40 ono
tail lights 200 for set ono
entre console 50 ono
clutch master cylinder 100 ono
brake master cylinder 100 ono
sun visors 20 each
wiper motor 50 ono
abs unit 150 ono
N1 coilpacks sold
interior lights 30 ono
pm for anything else .... thanks
https://www.sau.com.au/forums/topic/414948-r34-part-out/#findComment-6661733
UPDATE
floor mats sold
glovebox 50 ono
strutbrace 40 ono
sun visors 20 each
wiper motor 50 ono
abs unit 150 ono
cluster 200 sold
N1 coilpacks sold
https://www.sau.com.au/forums/topic/414948-r34-part-out/#findComment-6664609
hey did you end up selling your centre console? I'm after the armrest console lid.
also, do you have the parcel shelf with the mesh speaker covers that sit behind the headrests on the back seats?
https://www.sau.com.au/forums/topic/414948-r34-part-out/#findComment-6685495
  • 2 months later...
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
