decided to buy a cheap good standard diff for now maybe rebuild my other later
DIY saids it all lol shouldnt be too hard?
My diff is fked too....
Ive been looking and reading for a while, it seems the only good solution is rebuild with a Nismo centre.
Shimming doesnt last long and may wreck the other bits in the diff, and therefore cost more to finally fix.
My biggest problem is finding someone to do it well, Diff Dr is good but way expensive.
Edited by gus's r32rb25det
Changing the whole diff isnt too hard.
Rebuilding a diff well is tricky. you need to know about all the details of clearance and gear meshing, correct backlash etc.
And the gear to measure all that. And possible machining etc.
Ill leave that to the pros.
Looking for random interior bits for R32. LH A/C vent, and other bits and bobs. Let me know if you have anything and ill see what i have. Also looking for a set of NISMO floor mats, no rush on those though.
I have full ac and heater from 32 gtst. Its a BIG pile of stuff.
A new outside air sensor too, in box.
Also some airbox thing for GTR, ill get a photo, dont know if itll fit yours. Its Richards old one.
Have old vents, one is still unbroken ill have to see which side.
Yup i have everything In the car... I need all the shit that goes under the bonnet as it was ripped out on import.
Looks like a panel filter box for gtr, 2 inlets.
This aircon stuff enough?
not sure Mik ill have a chat to my mechanic when its in later this week/next week to find out exactly what i need. thanks!
And agree with Richard that does look like an ARC box.
Edited by Anfanee
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
