how much are looking to buy for? Might let go of mine for the right price but just put new tyres on last week.
Willing to negotiate man, i know they are worth a fair amount still :) message me your price
Me too. Ebay is cheap lol, maybe we can get a deal for two haha
I'm actually trying to track down a nismo one at the moment hahaha
If i can't find one ill let you know what i do end up getting before i order.
  • 1 month later...
WTB working R33 gts-t cluster.
Prefer Auto but manual will also work. Not fussed about how many KM'S are displayed.
Cheers, Luke.
Yeah man i have a Manual one! Im in Macgregor!
