I'm having a problem with my r33 gtst was running fine then I installed 750cc injectors, 044 external pump, walbro 255 intank, microtech lt16c plug and play, removed all the idle control off the manifold, eboost 2 and now the car won't turn off if I turn the key off or even take it out the car will still run then if I stall the engine the reds are still on the only way to get them off is to unplug the computer the car has an alarm but doesn't work (well I can't work the stupid thing) and it also had a hks turbo timer. my plan is to remove the alarm and turbo timer and see what happens. or could it be a fult with the computer it's brand new so ill ring the bloke I got it off tomorrow just wanted to see if anyone can help thanks
https://www.sau.com.au/forums/topic/415328-need-help-car-wont-turn-off/
id be thinking the turbo timer first..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
