Hey guys I have my mates r32 I'm selling for him as does not have the time spare to sell it.
I'll do dot points because that is way easier and straight to the point.
-THE GOOD-
-new respray
-133kms
-turbo
-auto (so the missues can drive it)
-17 inch japlish mesh wheels 70-80 percent tred
-3inch cat back exhaust
-comes with standed exhaust
-has a new pod filter
-front mount
-Gtr genuine alloy bonnet
-Gtr genuine front bumper and genuine Lip!
-Gtr genuine front Grill
-turbo rebuilt 4kms ago Zero shaft play!
-sparco boost gauge (need to reconnect )
-comes with 12 Months VIC REGO!! (no road worthy)
-comes with a alpine cd player
-Has Rare light up skyline rear light
-The Bad-
-the body is a bit rough and has some rust on one of the gaurds and a bit on the firewall
-starter motor is on the way out
-a bit of dodgy tint on the back window
-3inch exhaust has a few holes in it so it sounds a bit tinny
-Summary-
The Skyline is great to drive has plenty of power for a rb20det,
Very easy to park great turning circle and very comfy to sit in
It desperately needs a new loving home it's been neglected for over a year sitting outside a garage in the weather runs perfect please come have a drive and check it out! No time wasters!!
-Price-
He's looking for $$5000ono with 12 months reg
Please pm for more info I will get photos up asap
Thanks matt,
Just needs some bad tlc
FORGOT TO ADD ITS IN VICTORA AUSTRALIA
will add pics soon as i can get a few snaps! please pm me or shoot me a text 0402948881 if your after info
heres the pics
as promised.
keep in mind that this car has been sitting for over 6 months just needs a bit of TLC! :) it has a few rough spots but overall its a great skyline to drive!
also has had the ac re-gassed but just carnt get it to come on been told its a sensor inside the car that wont let it turn on
sorry guys it i have just been informed i have put a mistake the r32 will come with 2months reg till feb at 4.5k sorry for that.
  • 3 weeks later...
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
