Took the actuator off and found the wastegate is fouling on something, totally jammed open now.
Thats obviously why it was boost surging.
JJR split dump needs to go to the dump. Worst fitting thing ever!
Maintenacne on 34 this arv
New plugs, filters, oils, injectors cleaned, degrease, tyre pressures, finally a suds and then brazillian :D
Ooops and new brake light globes
right after a siesta......Zzzzzzzzzzzzzzz
Well not quite to plan - farkin RB25's. Nothing is as easy it could be. :verymad:
Give me the RB26 any day!!
To change plugs almost had to strip the bloody rear of the engine bay. Started late and ran out of daylight.
Coz I did on my drive way I have to finish it off tomoz. Just got to put all the piping, electricals and covers back on.
Got the shits and broke the valley cover in half :rant: Went to time out :rant:
how do you do it, how do you put up with it.
No wonder there is no valley cover or cover on most RB25's.
To change plugs you have to start by taking off
  • strut brace
  • neo cover
  • unplug all the wire connections at the back (4or5)
  • undo the bolts on the cross over pipe
  • undo the hose clips
  • pull some hoses off front and rear
  • rotate the large hoses out of the way
  • undo the allenkey bolts on the valley cover
  • undo the bolts on the coil pack
  • remove the cool packs
  • remove spark plugs
  • and then reverse the proceedure
on an RB26 if you have a valley cover you disconnect ignitor (1clip), coil packs, plugs reverse order and DONE!!
  • strut brace
  • neo cover
Yeah get the oil filter off. o wait.
I have wondered about that with the whole NEO cover thing but it's still an adventure on a regular 25 nonetheless.
As there is no engine cover, there is no need to remove the strut brace but you have to...
1) disconnect 4 small hoses from the crossover pipe (for charcoal canister)
2) disconnect vac line to BOV
3) hose clamps on BOV & crossover pipe (IC pipe and Throttle Body)
4) 2 bolts holding the crossover pipe + wiggle it out to remove
5) undo allen bolts holding valley cover & remove cover
6) unclip all 6 coil plugs
7) 2 bolts / coilpack & remove coil + remove Spark plug and replace + reverse coil removal
8) repeat step 7 another 5 times
9) put all the rest of the crap back together + double check it's all good
10) Goosfraba.
:cheers:
It's a pain but nice to know it's another 5 - 10000kms til you do it again.
Rob either you or the shop will receive a call in 5-10k Kms :yes: I dont have the patience mate
This time I took a number of short (long) cuts. First time doing a RB25 - 4hrs :(
Hence broken valley cover, many droped coilpack bolts, much cursing and bark missing.
At least oil change was very easy. Took speshal care but still dropped sump plug in hot oil.
LoL - I drove around for 5hrs doing errands and being Taxi Mum - then decided it was time to do service.
Me not known for high I.Q :wacko:
Edit: Oh and I broke 2 of the little hose things for the charcoal Canister
If Needed... Twould be my pleasure. :thumbsup:
Not sure what the valley covers are like on 34s but if they are the same shape etc as 33s, I have a spare or 2 if you need 1.
LOL, your sposed to warm the oil up, not get it hot and yeah, them sump plugs are slippery little suckers.
Much fun to be had!
Will PM pic of my "broken" one. Just need to find north and south piece - lol
Yes Do. ^^^
Put my boot lid liner in that I finally managed to acquire. Looks so much better than the underside of a boot lid.
Now I just have to decide whether or not to get the Boot lid it was attached to:
A) painted to match my car so I can have 1 boot with spoiler and 1 without...
or
2) sell it.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
