Fits up nice, no probs.
Wastegate is nice and free now, car goes fine, seems like no damage. Battery still good.
Sweet.
Ooh... is that a Mild Steel Bellmouth?
When you've put it on, you wanna put my Stainless Bellmouth on for me? :D
Mild steel.. just as good, maybe better as anyone can weld it if theres any probs or mods.
Depends..... if its from the same factory as my stainless split, you can chuck it in the bin now and save yourself a huge hassle.
Or its a breeze when it fits like the new one, Just jap said the mild steel bellmouth is made here, and the stainless split was China.
Stainless Bellmouth courtesy of JJR !!! Figured for an extra $20 I'd get the Stainless to match the rest of my Zaust.
Does your car go any better or sound any different?
nope, same
if you think about it, the split doesnt make more power or anything cos the gate is shut with throttle on anyway...
Just thought it might flow a bit better and maybe sound a bit deeper / louder etc.
Wouldn't the gate be open at wide open throttle?
No, its shut making boost (mostly anyway) and as the pressure climbs, it pushes on the wastegate actuator, opening the gate and dropping the pressure.
The wastegate allows hot gasses to pass by the exhaust turbine without pushing it around.
When the gate is shut all the exhaust energy is pushing through the turbo, and spins the compressor making boost.
I didnt know any of this 2 years ago, SAU educates.
Yeah that's sorta what I mean, as in...
say if you have a 10psi actuator on your turbo and you floor it, the actuator is holding the gate shut until you reach 10psi (which takes no time at all) but then at that 10psi air pressure the actuator opens the gate to bypass the exhaust wheel and stop overboosting, giving you a constant 10psi of boost. Meaning that from say 3000 rpm to gearchange, the gate is open and both outputs of the turbo are releasing the exhaust gases into the dump.
whether it's a stock dump, split dump or bellmouth, but being that both outputs are pumping into the larger chamber of the bellmouth, I thought it might sound a bit fatter.
When I get my Bellmouth on, it will be an upgrade from the stock dump with a 3" frontpipe, where as you have gone from an aftermarket split dump to the Bellmouth which may not be as drastic a change power wise.
and yes SAU does educate but can also be quite misleading at times...
4WD/2WD button installed.
Lights up BLUE off (4WD) and RED on (2WD)
been meaning to do this for a number of years. Procrastination at its best.
Originally had a HKS Torque/Drag controller in her but that was put to better use in a 9.3 second GTR.
Niiiiice. This is a massive advantage of the R32's ATTESSA system in my opinion. lol. The ability to electronically switch to RWD mode without having to drop the front driveshaft.
Used it to jump start my Fozza. Took Fozza for a spin around the block.
Some white smoke coming out of engine bay. I am hoping it is just from dust etc. from sitting still for so long.
Going to hit the engine with some degreaser and hose it out tomorrow. See if that clears it up.
Ta Troy - it is fairly awesome
Anthony - Well you haven't smoked up the rear tyres then - lol -> (hoonish)
quick pix
note also the 4WD light comes up on the dash
Nope. Car is still to new im scared ill break it!!!!
Edit: spent 4 hours the other day trouble shooting my HICAS. Previous owner butchered it pretty hardcore. Turns out it has an electronic bypass using a switch. However the wiring was done so badly it can't be recovered. On top of that my rims are too big and will rub if i turn it back on. So im just going to remove the bulb of the warning light. And WHEN i find a job ill look into options...
Edited by Anfanee
Overboost again...
So ill wait for it to cool down and change the actuator back to the old one and the bov too.
Brown sludge in the radiator? wtf? i just cleaned it all out. maybe the head bolts needs a re-torque after all the overboosting. maybe the turbo seals are going.
Brown sludge is pretty common in skyline cooling systems, try flushing the motor and rad 1st, its easier than headstuds :)
WHen i replaced my manifold coolant hoses the other day they were 1/2 solid due to the crud build-up in them as it clearly hadnt been flushed ever lol.
Washed and Vac'd my car today. Also did a few little things in the engine bay, still pretty messy though :/
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
