Do it on the side until you start making to many clients and turn full time :D !
Would a carwash place (Machine thing - like the ones at the petrol station - Likes Waves at Gunners) will that damage my paint work? I have a few bits of paint scratches and 1 rust spot - would a high pressure gun / carwash machine peel the paint?
Edited by Jeremy90
Sinister, you put up a number for a bloke from Tire wholesalers a while back, for mike or mitch or something? Well actually have money for tires now and I can't find the number.
Thanks mate. I'll become a member soon, just so I can throw the '33 down the tarmac a couple of times. Found some PZero Neros for cheap, so they will last me until the end of the year...
Started stripping it, and removing obsolete bits. (aircon pump finally gone)
In preparation for new injectors, timing belt etc, waterpump, Z32 afm, fancy timing gears, Nistune, radius rods, and a clutch.
And some little things like a battery isolator, re do the gauge mounting, some more stickers etc.
Wow - getting stuck into it Michael. Rip it all out maaaaate
No aircon ?? - you setting up a track car ??/
well I did the usual when I got back from Belco ghetto (washed/polished the cars).
Then decided I'd do something really simple - remove the cabin rear view and paint the back of it black.
Fark me while removing I broke the friggin mirror in it didn't I. *&^%$ Live n learn....
Oh oh oh - the bonnet came up like black glass today :D
Spewan! (mirror)
Aircon just made it overheat, but i am making an extinguisher bracket for track days.
Wouldnt take much more though... some brakes and a seat.... hmmm. I need to keep it road legal. And have a loud stereo.
If i was going full track car id strip it to nothing, then build up with a plan. One day.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
