its all sitting in the corner of my shed.
no lines cut, the whole thing, come and take it away if you want it.
only problem is if it dont fit then you have a big pile of sht in your shed to get rid of.
are ya feelin lucky?
Went for a nice drive out of town to test out the new radiator.
Success! Overheating issue solved ==)
Now just to find the rattle/knocking at 120kmph... :wacko:
Private Roads... Gotta love 'em!!! :ninja:
So what Radiator did you end up getting? What coolant you using? Did the fan shroud fit? Thermo sensor? Still using the Clutch Fan?
Check for Stray current that may cause your radiator to eat itself in less than a month? So many questions... :laugh:
If you are just going to chuck it ill take it to give it a go lol
I got a 42mm chinese ebay one. http://www.ebay.com.au/itm/190700402072?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
fit straight in perfect. stock fan, shroud and sensor no problems. didn't check for current (forgot)
Using Tectaloy 50/50 premix with glycol (or whatever it is. i'm tired and cant be bothered to think, lol)
Gave the pod filter a good clean. DAMN that thing was filthy!!!! and made a new bracket. to hold it in place nicely..
Now just waiting for boost gauge to start next step =)
I think the only issue that would arise would be capturing other people's info like car, rego. Privacy Act is a touch and go thing in AUS. Hence why when cops pull you over with recording devices they say that they are recording you as a pre warning.
Are they allowed for insurance reasons, if given the police officer in question asks about it? Not real sure how to avoid other people's privacy but given it's a public place, recording and taking photos is allowed generally.
Record everything and let the courts worry about it
This.
Also yeah Jeremy I'd think being in public, you're right that there's very little 'privacy' against photos etc...
A myth/rumour I'd like to know the truth behind though, is the one I always hear about it being illegal to record conversations with police officers (sound or video) when you're pulled over for example - even if you advise them you're recording. Anyone know the go with this?
From my understanding and not sure against Feds but, you have to advise whether or not you are recording video/sound (or not). The police officer will then request for you to either turn it off (Which you have to) or he will acknowldge and proceed with defecting you :P
Anyone have any cop m8's? My m8 has a cop friend. Might get him to ask him. Also, becareful, you can be arrested for not having more then $5 on you at all times (True law - but not policed :P) Infact, a guy in Melbourne got recently questioned for not having any money on him - mind you he lost his wallet.
Funny laws.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
