Looks good :thumbsup:
Yep - change the colour of the fog light surround to Black = win
Last night went round to Robs to pick up a sedan pair of foggies I purchased as I prefer these over the normal coupe ones. While I was there we also slapped on a sedan grill just for shits and giggles to see how it looked over my m spec grill. And I think I actually prefer the sedan stuff... Maybe I should have just bought a sedan.. :/
Anyway, foggies installed this morning. Think it looks much nicer this way :D
I'm in.
and BTW why didn't you flaming mongrels let me know you were out drivin huh ?
I was actually sitting at Pine Island after my drive when I posted that. Thought about calling you but didn't want to disturb your secret cross dressing time. :rofl:
Dang - and you look so good in fishnets. Dude !
Should of buddy. I have bourbons and a spare room (no lock on the door either ;) )
PS: Girl Friend is comming over :3some: - Sweet ! She has 2 single sisters !!!!!
(That's me in the middle)
No crossing the streams :starwars:
Bahahha
One more edit: I'm making Salt and Pepper calamari and a Thai curry prawns on rice for dinner :D
Aussie prawns and NZ Calamari - FRESH !
Thanks mate, but I wanted to get back home. The Mrs EX has been moving stuff out all day. (hence me going for a long, fun, solitary drive)
and she just drove away this second so yeah... :(
PARTY AT ROB'S HOUSE ANYONE???!!! :woot:
:banana::bunny::3some::bunny::banana:
That's good news mate. Seriously - GOOD MOVE :thumbsup:
Hope nothing of yours just drove away too ... besides cum stains.....sowwy! was funny in my head!
Can't come party - have Orgy to orgynise :P
edit: You need anything just give me a call
2nd edit: seing your single again, get rid of the Penal in your sig! attracts the wrong sort, know wat I mean :nyaanyaa:
I remember why i havent changed a clutch for 15 years.... bastard of a thing.
Finally worked out the twist to get the box back on and now i realize i didnt push the aligning tool all the way in and missed the crank splines.
>_<
So back out with the box..... loosen the clutch off gradually and evenly, align properly, and back together all over again.
First times a bitch, but im learning the tricks to this car.
Just plumbing.
A cock is a valve.
Ballcock= ballvalve.
Lots of cocks in plumbing.
Tomorrow is gonna be Cockstop! Just a heads up. LOL
Very sensitive
(and slightly homophobic I'd say from my comments)
Sensitive I can relate to my fellow Cancerian.
Crossdressing Homophobe? You need a Shrink!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
