Finished up all bits and pieces for the tune on monday.
Eliminated 3 switches by hooking stuff up properly.
I hope they dont have to fix too much of my work.
I was trying to fix problems before giving it to them, i dont want to give them problems.
Anyway ill post dyno results when done.
Hanging out for a drive, it been off the road a while now.
Oh no, it wont go. Im getting a tow truck there.
New fuel pump, bigger injectors, z32 afm, means it wont run before a tune.
Not to mention the timing would be out (new timing cover, no marks), and the cam gears may need a slight adjustment.
but when i get it back.......... :D
Do you have the Nismo clutch? Because if you do - I hate you !!
Nah not really. I had difficulty getting one in a hurry so I have gone for something else.
I needed one this week not in 2-3 weeks time.
They're going for a great price $1700 from OS delivered to Aus :woot::woot: , but those shops who have them in Aus are still asking $2400 to $2700 :rant: Damn rip off merchants !!
The twin coppermix was my first choice :(. After reading I would now go the Competition one :thumbsup:
Install is half to full day depending on shop. DIY :yes::yes: .
I haven't done one so I'd be in the same boat as you (need someone who has and the equipment. Definitely need it lined up too).
Should be ready to pick up tomorrow afternoon.
For everyone else - keep an eye out. Because if you need one I may be organising a GB...soon
I bought mine a week ago give it about 3 weeks i told them to put a fake sticker so that i do not get charged duty for it. Ill take pics when it arrives.
DIY?
You need:
To take the flywheel to get machined, so if they cant do it straight away it holds up the job.(machining takes about 1/2 hour)
Compressor and rattle gun to get it off.
and the usual jack, stands, tools, etc.
I have an alignment tool if you need it, standard nissan 24 tooth, works for gtst.
Mine was an utter utter bastard, as theres not much room and you need to sort of twist and push and lift to get it in.
GTR may be better with clearance but will for sure be heavier.
Recommend getting a mate to help with the wrestling.
The benefits of DIY are you can take the time to do a perfect job, double check it and sleep well.
The new kits come with a new flywheel which is awesome could save yourself some bucks and time. Not sure how much it osts anyway to get it machined
going to pick my toy up today - 314.5kw on 20 psi.. thankyou to ed at autotech
Any news on these guys?
Picked up mine today, new clutch in :D
It will take a little getting used to as it's a lot lighter than the OS Giken. Stalled it leaving :unsure:
Got most of the way home and then had to stop at one of the big circles. Thought to myself don't stall it, don't stall it so kept the revs up, release clutch
Traffic coming on from my right must go now .....
Ended up launching and chirping through 1st/2nd.
reminder to self - must NOT launch hard or often with new clutches (as it is no good for them, bed in properly)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
