That's pretty good man. Who did you go through? I've got a rust spot / paint chip on Rosie and want it patched all up.
Guys I went to are David Hand Smash Repairs. Definitely recommend then although Fyshwick is probably a little far for you. I hear there are a few good paces around Mitchell. Just shop around get heaps of quotes and you'll be right.
  • Like 1
Evenly rolled guards, takes a bit of time.
Wheel on, measure, wheel off, roller on, heat and roll, roller off, repeat untill even on both sides, front and back.
Hardly any paint cracked....... on the last one. >_< doesnt matter, paint coming soon.
Final adjustments may be needed, i need tyre on to see.
its Canberra nowhere is too far for a good job
Yeah I thought it was a Bargain! Came from W.A. (Ebay) --->> http://www.ebay.com.au/itm/300900010454?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1821wt_902
Price is slightly higher now. :D
(Baby Burnt Himself with a Cig, Smoking really does harm Babies.) LOL
OEM = Good in coilpax :yes::yes:
Its just there a lot more expensive usually than splitfires.
Splitfires are just as good if not better but usually cheaper.
( I maybe killing myself smoking but I intend to take passives with me - Mehehehehe :devil: )
Edited by Sinista32
Washed the 34 after having some more work done. Jeez it looks Trick and feels quick.
Now if I just had one of those Alitia front bars to add some evil presence.
May have to get me one !
IF you like ill give you 10k for the 32 in cash now so you have more moneys for the 34.... :woot:
for $10k you can sit in the passengers seat of my 34 - lulz
but x 4 them dollars you can buy the 32
(when 32 is back you gotta come round mate :D)
Edited by Sinista32
Okay :(
Sounds good ill bring some beer around :geek:. not long now..... :laugh:
Got my front tyres, 235, 40, 17.
now have to work out exactly how much wider i can go for the back
post-89755-0-84320700-1377849768_thumb.jpgpost-89755-0-14005600-1377849785_thumb.jpgpost-89755-0-08765300-1377849799_thumb.jpg
255? would be nice
Opinions appreciated.
Pics are of 235s on the back
Edited by D.I.Y. Mik
Wow! She is gonna look SIK MIK !!!
Put both on one side and take a pic?
Might just be what you need to keep traction up that Hill. ;)
What tyres did you get?
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
