Think the hardest part was actually getting the harmonic balancer off. Both the pullers we have don't fit it and we had to create our own contraption. Did the job though
Yeah I am 100% getting one now.
Just got a little bit more to save and sell a few shares (After election date)
Then I will be talking to iron chef again.
Pretty sure I am going to go black as well.
Just really depends what comes up at the time
  • Like 1
you can always get one before raising all you money. Depending on who ur using. I paid Jspec 1000 to look for one and when they got it i just had to pay the price of the car which will be -$8000. Then the rest you have to pay the shipping when it arrives, then the rest after compliance.
Don't want a GTR.
Looked at the possibility of getting a 33 GTR for a few grand more.
But it will be older and it's more expensive if things break.
GTT is the way to go for something simple and nice to drive.
and because NEO
soon, very sooon
Edit: btw - GTT's are cheap as chips.
$2-3k will get you good reliable 300ish kws too
Already got my stuff I can transfer over ;)
Also 3-4 years ill be richer
So I will be fine with parts needing replacement more frequently. haha
This is true. Im glad that my engine work is 90% done.... I've already told myself im limited by the turbos. So if i want more i have to max them out properly. Next will be throwing in a Haltech and E85 Flex, New suspension, new wheels, and then all new interior.
But looking at the fact my wedding is looking at between 20 and 30k and ive just bought a house i don't think the GTR will be getting much more work for a little bit.
Solved the gas problem with a couple of air admittance valves (plumbing stuff)
Taped up all holes and gaps, even some expanding foam filler in there, to seal the cabin from the boot.
An aav where the window wiper motor was, sucks air from the cabin into the boot.
One in the boot sucking air out to under the guard
post-89755-0-30743500-1378104032_thumb.jpg post-89755-0-05176200-1378104047_thumb.jpg
Now when i shut the boot it feels right, like a bit of air pressure.
Havent tried it on the road yet.
But it should work like it has all the original stuff still there. (plastic sheeting, rubber flaps etc)
Edited by D.I.Y. Mik
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
