New studs in (had to clean up the nuts with a tap as they were binding on the new studs), cometic exhaust gasket on
and new turbo gaskets on and lines hooked up
Time to head home and finish a job application and come back tomorrow and fill it with fresh oil and coolant, hook up the dump pipe and exhaust and start it to check for leaks.
Thanks man. The R32 actuator i got off you points a different way to the 34 one so ill have to take over some tomorrow.
So much evidence of exhaust leaking from the turbo flange and some of the manifold nuts were finger tight.
I imagine my exhaust will be much louder now :P
There is something weird going on with the stock boost control solenoid.
One of the hoses(top one i think) is blocked off with a screw and the bottom one runs to the air recirculation pipes. No ideas what's going on there :S
I'll work out which wire i need to earth tomorrow as well.
You don't want to earth it do you?
If plumbed in with the 32 actuator you'll get 12 + psi.
Just a hose from the turbo nipple to the actuator will give 10psi.
Take the solenoid out.
Wasn't there intact...it was lots of small pieces. Looking at the other blades it looks like it came off bounced around the other fins got chopped into little bits and the rest turned to dust. from what i could see anyway...i might take the cat off tomorrow bang it on the ground and make sure.
got my alarm fob working!! Now have 2 that work.. wish I knew it was so easy before..
also got new keys cut =)
its the little things..
oh, made a cardboard template for pod box just to see what I'm making and I rekon i'll just buy one. By the time I buy tools etc it will be about the same price and a lot less hassle.
What do you want from it? If stock boost, do the Free High Boost Mod first. 7psi all the time. :thumbsup:
Thread here ---->> http://www.skylinesaustralia.com/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/
Haha yea :) the guy before me blew the turbo. So he replaced it and had it running 12 psi.. He took the boost tee :( buy hay I'm only on my ls.. I don't need huge power from the girl !
What do you want from it? If stock boost, do the Free High Boost Mod first. 7psi all the time. :thumbsup:Thread here ---->> http://www.skylinesaustralia.com/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/
I'm going to sound like an idiot. Haven't read through the whole thing yet aha. Where is the solenoid :/
In robs first pic the top boost line has been cut and clamped and the black wire has already been earthed. But I haven't seen it hit 6psi
Edited by ..::R33GTS-T::..
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
