could be the bodies in the boot keeping it grounded
great outcome
(higher RPM and quicker release on the clutch)
Edit: Careful in the rain
Edited by Sinista32
  • Like 1
juat replyinG tall the negitive commenets , my mum has tons of experiance, yes she didnt like it but she did say it was careful driving, slowthe the corners 3/4 throtte on the straigts.. i nver brake the speed liit, and i have tons of experiance of cotrolling slides, (bosses farm) im never an idiot on the roads, but every now and agian i do accelerate hard.. i wasnt (racing) i just didntwant that asshole sitting on my arse, so i got infrount of a lancer and continued driving normally... the vl just hurd the turbo spool and flutter and baciclly thought ill show you, im serprised not dead.... 200+ in n 90 zone is just stupid... i know i dont have h experiance nor do i think im un killerbul, i hae been taught how to safly accelerate/brake, never leaving things to the last second... if i see a gap, i d think about taking it, yes i wont deny that but i never do, i think aout how i could kill someone or myself.. besides that i love my licance to much..
but on topic polished ad waxed my car, then took mates to the formal...
picked up my car whoooohooooo. 280kw But still no wheelspin damn RSR's maybe im a novice at wheelspin.
280kw and no wheel spin? must have amazing tyres... mine spines in 3rd (wet) and into second in the dry... dead stock...
+ Exhaust, Frontmount and 7psi fulltime. :whistling:
Washed all the Central West Roadworks Mud off my Baby.
She's All SexXxy again. :wub:
and some other little things ;) it dosnt have much more power then stock tho :) it looks nice tho Rob ;)
im sad to hear you you washed that 2-ton paint work off :verymad: it looked awesome to say the least :yes: i detailed mine today then mum drove it radically in a dirt carpark, to say the least i hadt to wash it agian for fomal pick up tonight :dry:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
