Good question Interested also as have pondered this previously
not sure if puff will run out on -7's before extra power potential from e85 realised
Edit: may have answer - same peak better response
Edited by Sinista32
Looking at around 335-340KW (I hope) with Much improved response.
Also it is just safer fuel. And for the $700 ontop of a haltech i couldn't not do a flex tune.
We will find out.
Current timeline:
Next week goes in for Haltech, 98 tune, replace some parts that are squeaking and new radiator hoses
Then:
Sell PFC, E-boost, Z32's
Buy HKS Air Flow Less adapters and the sensorz i will need
So in maybe a month? It will go to corn syrup
I bought my ecu specifically for its flex fuel ability. Tbh I don't think I'll ever use it. Once I go flex fuel it will pretty much never have e85 in it. I'd rather carry jerries and have all the powers :)
will work on that Rob
32/4 got a new mid muffler today, due to the cricket ball size hole in the original that appeared last week (25yrs old). Sounded tuff but I like the sound of silence. I still cant believe how lucky I was to grab this one !
34GTT is in getting all new suspension (coilovers etc), a full set of new shoes also. Car market dead so may as well keep and improve the beast. Not giving it away :angry:
Changing from RSR's to Falken Azenis 453's.
Found the RSR's not so good on RWD only skyline, noisy on the GTT, not so good on the street as they need warming up and found them quick wearing.
See how the new Falkens go.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
